Low Fuel Light?
Old May 16, 2010 | 04:01 PM
C_H_A_D's Avatar
Default Low Fuel Light?
My brother has a 99' ex V6 coupe with 120,XXX and the low fuel light came on when he was low on fuel, like it should have. He has since filled it up and it has not reset. He disconnected the battery but no luck. Any suggestions? Thank you
Old May 16, 2010 | 05:44 PM
sgraham01's Avatar
Default Re: Low Fuel Light?
try tapping on the tank with a rubber mallet to free up the float. may just be stuck. if that helps, add some fuel system cleaner to the tank and that may help keep it from happening again.
Old May 17, 2010 | 05:40 PM
C_H_A_D's Avatar
He tried it but no luck. I dont think the float is stuck because his gauge is working but the low fuel light remains on. Is there an easy way to disconnect it?
Old May 17, 2010 | 06:22 PM
sgraham01's Avatar
sorry, i just assumed that the needle was stuck down too. that's strange that the gauge is reading full (or not low) and the light is on. there may be a problem with the ECM not turning the light off, but it's hard to say without a wiring diagram of the system. try disconnecting the battery again for a longer time, at least 15-20 minutes to see what happens. I almost think that should set a code on an obd II car since the sender voltage is not correct for low fuel readings. sorry i can't be more help. You may have to take it in to an auto electric shop if you can't get it to reset.
rdone
Jan 5, 2015 04:01 PM
shogun1552
Mar 14, 2013 12:29 PM
dlbazini
Apr 4, 2009 03:21 PM
tkevin07
Apr 5, 2006 05:24 PM
GSRaCeRbOI
Sep 3, 2002 05:26 PM
