Looking for answers
I have a JDM B18C i think its a GSR the top end is stamped p72. The head is built and i have a skunk 2 intake manifold with a type r ob2 computer and an lsd tranny. do i currently have more HP then a usdm type r ??????????
What do you mean by built? What cams? If it's anything more than stock ITR cams by running the factory ITR ECU you probably aren't gaining anything. I've seen GSR dyno results where they installed skunk2 cams and made 2whp more (literally) than previously, which was still less than most stock ITR's, because there was no tuning.
i had my ITR motor throw a piston form a bad sleeve. I then put in a stock JDM B18C with a skunk 2 intake manifolod. I also had the head port polished and flowed. I still have my type r tranny and computer
As long as it's a healthy engine you are probably putting down comparable power to a stock ITR motor. As long as you had the head on a flow bench after the port and polish to verify that you didn't actually lose flow, which i have seen on honda heads alot. ITR heads are hand port and polished, and a skunk2 intake manifold is basically just a carbon copy of a stock ITR manifold. The only thing that might be holding you back from making the same power could be a lack of ITR cams, or comparable cams.
MAperformance
52
Sep 20, 2009 07:01 AM
rare92gsr
May 29, 2007 09:18 PM
