What are people using for boost control for wide range of psi?
Old May 16, 2010 | 11:53 AM
Pumpking.'s Avatar
Default What are people using for boost control for wide range of psi?
What type of boost control are you all using?
on my car, im running stock ecu, and the stock solenoid for boost control isnt cutting it for bigger boost now. i had to put an 18lb spring in just to reach 29-30psi w/ maxed out DC. and w/ 18psi base pressure in 1st and 2nd, im just spinning like crazy on the streets.
im trying to get the car dialed in for the track so i dont have issues in the first 330'.
since i'm running stock ecu, i don't want to opt for anything standalone ecu related (aem ems, etc)
i need something that is capable of letting me run a light spring, but run upward of 35-40psi. i know it can be done.
I need boost by gear, and even boost by rpm with that would even be better.
anyone running a 4-way boost solenoid instead of the typical 3-way? it's suppose to allow for a way wider range of boost and a use of light spring?
I seen the turbosmart Eboost2 'sport compact' but after reading the owners manual, it doesnt seem exactly the most friendliest of boost controllers.
any suggestions would be awesome.
Old May 16, 2010 | 01:24 PM
locash's Avatar
Default Re: What are people using for boost control for wide range of psi?
Hondata S300 with a mac solenoid, try lower frequencies to get more boost out of it.. Works well for all the cars I tune..
Old May 16, 2010 | 01:30 PM
Pumpking.'s Avatar
are you using the standard 3-way mac solenoid valve that is popularly used? what size spring, and what is your max boost?
and on top of that, are you utilizing both ports on the WG?
basically right now, i got one line that goes from the solenoid to the turbo, and another from the solenoid to the bottom nipple on the WG..
im wondering if upgrading to a mac 3-way solenoid and switching the vacuum line setup to utilize both WG's will allow me to reach my desired boost, with a lighter spring.
ultimately, im looking to run a 12lb spring, and be able to run 35-40psi..
thanks for commenting..
Old May 16, 2010 | 01:33 PM
boostedcivicsir's Avatar
Mr. Badwrench
im using the aem/mac solenoid. holding 34 psi at 10.5k. with a .9bar base.
Old May 16, 2010 | 01:41 PM
Pumpking.'s Avatar
awesome...this is exactly what i was looking for/wanting to know.
can you tell me how your vacuum line setup is?
im going to order a MAC solenoid right now. im pumped to know my goals arent far-fetched.
Old May 16, 2010 | 01:55 PM
Pumpking.'s Avatar
aside from running it to only the bottom port, the 2 forms of diagram setup for both WG ports seem to be this:
is one better than the other?
Old May 16, 2010 | 03:26 PM
DRAGLS's Avatar
I use neptune with boost by gear.
you need to get a 4-port mac valve which allows you to control the top and bottom
of the gate.
I personally run a 7lb spring and have gone as high as 36psi without any issues.
Old May 16, 2010 | 03:32 PM
Pumpking.'s Avatar
of the gate.
where can i find the 4-port mac valve at? I'd really like to experiment with boost control setups for this season.
After looking at MAC's pdf, im pretty sure i need model #:
46A-AA2-JDDA-1BA
knowing the model is 1 thing, finding someone that sells it is another. Turbosmart sells it, but they want like 130 for it when i seen similar model 4ways (but not the 1 i need) for like $50.
Old May 16, 2010 | 03:34 PM
Mr. Badwrench
withoug looking at my car because i know im not using all 3 ports, it is the one on the left. i prefer to have the boost reference off of the turbo. some people dont, but id rather regulate the boost from the source not at the manifold.
Old May 16, 2010 | 03:35 PM
locash's Avatar
I run the typical mac valve, 8 psi gate springs, running 8 psi up to 36 psi.. Hook it up like your first diagram, port 1 on the valve to the bottom of the gate and the compressor outlet, port 2 to the top of the gate, middle port on the solenoid (port 3) is the vent.
Old May 16, 2010 | 03:50 PM
Pumpking.'s Avatar
46A-AA2-JDDA-1BA
the grainger 4-way solenoid that works:
http://www.grainger.com/Grainger/items/6JJ40
id prefer a MAC so ill see if i can find the mac 1st.
prolly guna play with the 3-way and 4-way and see the differences and what i can get away with.
thanks so far to those giving details on their boost setups.
Old May 16, 2010 | 04:03 PM
DRAGLS's Avatar
No ,the 4-port you want is a 45a it cost $36.
Old May 16, 2010 | 04:18 PM
Pumpking.'s Avatar
thank you very much dragls. i was able to source the 35A 3-way's easily, but wasnt sure which solenoid model i needed for the 4-way.
this is the diagram ill be utilizing for the 4-way:
going to order both and give them a whirl!
Old May 16, 2010 | 04:25 PM
DRAGLS's Avatar
Thats how mine is setup.
Also if using Hondata or neptune it still a 31hz valve.
45A-AA1-DDBA-1BA 12V 5.4w
Old May 16, 2010 | 05:28 PM
hello1320's Avatar
CO2!
Old May 17, 2010 | 06:58 AM
FRernesto's Avatar
Do what he said, he knows what he's doing!!!!!
Old May 17, 2010 | 08:00 AM
96 GSR-T's Avatar
In for the results of this, I would also like to run 8psi up to 40psi or so without CO2.... I was going to get 10psi springs and hope for the best but if this works I want lighter springs.
Old May 11, 2011 | 10:00 PM
Muckman's Avatar
Moderator in Chief
Pumpking - how did this configuration work for you?
Locash - How are you getting 4x wg spring with the standard 3 port ebc configuration that everyone else nets 2 - 2.5x wg spring?
Old May 11, 2011 | 10:06 PM
jdm inc's Avatar
s300 with a mac valve here.15 to 30 lbs so far.
I have mine setup like this.
Old May 11, 2011 | 10:22 PM
Zer0_SpeedWorks's Avatar
nlr with humprey noids on co2
Old May 11, 2011 | 10:25 PM
Muckman's Avatar
Moderator in Chief
Please post your boost ranges and how you have the solenoid plumbed.
Old May 11, 2011 | 10:43 PM
redboost10's Avatar
10 psi springs running 37-39 psi, using regular boost solenoid with vent
Old May 11, 2011 | 11:32 PM
Pumpking.'s Avatar
the solenoid ended up not being compatible w/ the EBC that I used (N2MB, made specifically for the srt-4). I worked with the software developers for a bit specifically trying to get it to work, and it never panned out correctly.
ended up using the diagram on the left, in post #6...utilizing a DTEC EBC. had boost by gear, and by rpm. i've used several other EBC's before and hands down this is the best one i've used to date. simple to setup, and worked great.
I didn't get the eboost2 like i was thinking about getting earlier in this thread, because I learned the eboost can only be ran w/ boost by gear by setting up input switches that you'd have to manually switch each gear. the dtec you just calibrate each boost map to each gear you plan on using the map for, then its done. no switches or anything.
9lb spring, and it ran 40psi on 95% DC in 3rd gear and about 89-90% DC in 4th gear. 1 46mm WG.
fwiw, if anyone's interested in it (i'm guessing not since alot of you guys have the opportunity to run hondata or run ems), but the dtec's fs since i'm parting out.
Old May 12, 2011 | 08:23 AM
EnFOURcer's Avatar
That is not exactly true. Yes, switches are one way but the EB2 does not know where its getting its inputs from.
Another way is to program an AUX output on your ECU to ground the AUX inputs on the EB2 accoding to the gear you are in.
Old May 13, 2011 | 01:39 PM
Muckman's Avatar
Moderator in Chief
Is anyone using the "two port connection method 2" shown below? That configuration seems like it would net the widest boost range. The solenoid would effectively switch boost reference from the bottom port to the top port allowing for maximum pressure differential.
