gsr axles in lsb18
Old May 16, 2010 | 10:23 AM
turbotegy10's Avatar
Default gsr axles in lsb18
will the gsr axles work with a lsb18 tranny. we are having problems with both axles sliding out while driving. can anyone help us.
Old May 17, 2010 | 05:50 AM
rankin_wanavtec's Avatar
Default Re: gsr axles in lsb18
sounds like youre using eg axles on an integra.
Old May 17, 2010 | 04:26 PM
they are actually on a 94 civic not sure the model its a friend of mine
Old May 17, 2010 | 05:14 PM
mouab18c1's Avatar
So what motor is in the 94 civic? Seems to me like you guys are using wrong axles. Which is why they are sliding out because they are too short.
Old May 20, 2010 | 10:04 AM
its a b18 motor and that was my first thought aswell. but not sure
Old May 20, 2010 | 01:54 PM
mouab18c1's Avatar
Make sure they are pushed all the way in.
Old May 20, 2010 | 05:04 PM
we just decided to replace them. they were forced into the wheel hub with an impact gun it was a pain in the *** getting them off.
Old May 20, 2010 | 05:27 PM
Jimmy's Avatar
Global Moderator
Are the clips on the axles?
All 94-01 integra axles are the same except for the ABS ring..
You can use 94-01 integra axles or 99-00 Honda Civic SI axles.
Old May 20, 2010 | 05:48 PM
yeah the clips are there. they axles just kept sliding out of the tranny. couldnt figure out why. they looked to be a different diameter than the ls but thats just setting them next to each other and glancing at them.
Old May 20, 2010 | 05:55 PM
Jimmy's Avatar
Global Moderator
I would try to verify what your trying to use before attempting tor reuse them and possibly cause internal damage to your transmission.
mrbutters
Mar 15, 2009 05:49 PM
BigLoadChoakHard
Jun 10, 2003 04:39 AM
TypeRod
Aug 21, 2002 10:48 PM
