power steering d-series to b-series
anything special i would need to do to make power steering work with my b-series swap? or do i just take the pump off the d-series and bolt it to the b-series?
sooo let me comfirm my options?
i have 2000 civic ex with d16y8
swaping in b16a2 with 2000 gsr head.
1. p/s bracket from 94-97 del sol bracket and the d-series p/s pump will bolt right up?
is that the only bracket i can use? or can i get like a 99-00 si one?
2. p/s bracket/belt from integra?
3. according to this https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-retaining-power-steering-ek-b-series-swap-1822781/ i can use 99-00 p/s pump and everything should connect properly?
any other options i have?
thanks
thanks
iirc i think you can get any b series ps bracket. ps pump must be from obd2 b series. ac bracket must be from del sol v-tec trim or crv. correct me if im wrong.
well looking at this https://honda-tech.com/forums/showthread.php?t=1822781
seems like the b-series pumps from integras wont fit my lines even if they are obd2.
maybe i can only get the 99-00 si pump.
any b-series lower bracket, but i need a p72 upper bracket.
thats what im guessin, let me know if anyone knows any other options. so i have a wider choice of things to look for
and gettin my swap goin faster
pvt_awol
Apr 21, 2009 01:47 PM
GetawayInMoscow
Mar 28, 2009 10:25 AM
rextec
Mar 9, 2006 01:16 PM
