y8 or z6 cam gear? (d16y8 block z6 head)
Old May 15, 2010 | 01:37 PM
vtec8200's Avatar
Default y8 or z6 cam gear? (d16y8 block z6 head)
which cam gear do I use with a d16y8 block and z6 head?
thanks!
Old May 19, 2010 | 10:13 PM
lunch_box_4_life's Avatar
Default Re: y8 or z6 cam gear? (d16y8 block z6 head)
you def. want to use the cam gear that is mated to the cam if your useing a cam from a z6 use the z6 gear the y8 gear is set like 8 degrees different than the z6
Old May 20, 2010 | 02:33 PM
vtec8200's Avatar
Thank you.
And if I use an adjustable cam gear for a y8, how much do you need to retard the timing?
boun4door
Oct 21, 2008 05:46 AM
nikolass
Oct 4, 2006 08:33 AM
SOHC_MShue
Feb 7, 2004 06:18 AM
