I know my engine is gone!!!
Old Sep 12, 2002 | 12:09 AM
Isaac's Avatar
New User
Default I know my engine is gone!!!
I am sooo mad, confused, worried, etc. If anyone else read my previous thread, I just installed some Skunk2 Stage 1 cams in my B18C1. The Skunk2 Gears were at Intake -2 and Exhaust was -1 and I just drove it like that for one day because it was late when we finished and I was unsure how to adjust the timing.
Well, I find out how to adjust the gears, so I adjust both gears to 0,0 and start my car. It sounds fine, the idle is kinda rough, but nothing bad. I drive slowly around my neighborhood and then up to 40MPH, not going over 3000RPM's just to let my car warmup. So I take my car out onto a 50MPH road and rev to roughly 7000, so around 55MPH and suddenly my check engine light starts blinking and I can hear a ticking noise (MY VALVE(s) BENT I BELIVE). I'm at this point just thinking, ****!!! I get to the next light and my car just dies and my oil light goes on. Keep in mind I just barely changed my oil 5 minutes before I drove. I keep trying and trying to start it up and it won't start until at least 5 minutes later, but it's very loud and very rough. I end up driving it, with my check engine light blinking as well as my oil light on and on top of that everytime I had to slow down and when my RPM's dropped low my car would just die. Luckily I was only 2-3 minutes away from home. Also, tons of smoke was coming from my car this entire time. I finally got home and I'm just scared (yes, scared). I pulled the CEL codes and I got a 71, 72, and 67 (which was already there). Here are the CEL problems: Cylinder 1 & 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire. I'm very worried and I don't know what to do? I checked the timing belt and it looks ok, there's no leaking from the valve cover and the gears are still at 0,0. What did I do wrong? What should I do now??? What can I check?? I know it's a lot of questions, but I can't handle this both because of time and money. Please help!
Old Sep 12, 2002 | 12:18 AM
uNF$@#!'s Avatar
Default Re: I know my engine is gone!!! (Waxing "The Carrot")
sounds you didnt adjust your cam gears correctly and messed up your ignition timing.
what you can do is get the car towed into a shop to get it fixed.
Old Sep 12, 2002 | 05:11 AM
Isaac's Avatar
New User
Default Re: I know my engine is gone!!! (Soup ****)
I did adjust my gears right though. They have been and still are at 0,0. Considering that I bent valves, what needs to be done? Generally how long will it take to get fixed and how expensive is it?
Old Sep 12, 2002 | 05:22 AM
MPH's Avatar
MPH
New User
Stainless steel valves $18
Machine shop labor $200
If you pull the head $free
Shop pulls head + new headgasket $450
Old Sep 12, 2002 | 08:25 AM
Black R's Avatar
25 Year Member
what is your full setup?
I can't imagine the stage 1 cams would give you any problems with valve to piston contact on a stock bottom end... You should have at least 5 degrees to play with...
What is your timing set at?
Old Sep 12, 2002 | 08:55 AM
RATEDR's Avatar
Sorry to hear about that. Might should have taken it to a shop to install them, that way if anything went wrong it would be on them and not you.
[Modified by RATEDR, 1:37 PM 9/12/2002]
Old Sep 12, 2002 | 09:31 AM
Isaac's Avatar
New User
Default Re: I know my engine is gone!!! (Black R)
Thanks everyone....
My car's timing is stock and I was running my stock valvetrain, but it shouldn't be an issue because I didn't/haven't revved over 8000 RPM's. All I have is Skunk2 Stage 1 Cams/Skunk2 Gears/JDM 4-1/CAI and then suspension. I'm not sure what's wrong or what's going on....
We'll just say that I'm really worried and that's an understatement.
Old Sep 12, 2002 | 09:38 AM
sgT's Avatar
sgT
Stock gsr springs arent gonna cut it.
all you have to go into vtec and something bad could happen.
Old Sep 12, 2002 | 10:00 AM
Hooch'n's Avatar
Default Re: I know my engine is gone!!! (sgT)
Old Sep 12, 2002 | 10:06 AM
95GS-R's Avatar
With the skunk cams or any cams that are not the ones the car came with? How about ITR cams? I think skunk 1's have the same kind of profile as the CTR cam.
Because I have been driving around with ITR cams in my gs-r for a while and things are ok so far. I read quite a few places saying I didn't need to upgrade the valve springs if I didn't want to rev of 8 grand.
What is you take on this sgT?
Old Sep 12, 2002 | 10:13 AM
Isaac's Avatar
New User
Default Re: I know my engine is gone!!! (95GS-R)
That's exactly what I was thinking.
Old Sep 12, 2002 | 11:43 AM
Malice's Avatar
New User
even with a stock ecu? he should be ok. i know alot of peeps, including myself running stock gsr springs with these cams
Old Sep 12, 2002 | 01:48 PM
dohcsideSi's Avatar
i would double check the timming and make sure the belt didn't jump at all...the skunk 2 stage 1's aren't big enough to cause any kind of damaged at +2 degrees.
Old Sep 12, 2002 | 02:00 PM
Isaac's Avatar
New User
Default Re: I know my engine is gone!!! (dohcsideSi)
https://honda-tech.com/zerothread?id=277717
Old Sep 12, 2002 | 05:08 PM
owen_the_soyboy's Avatar
install problem?
did you check your timing with a timing light?
were you using the correct marker on the crank pulley?
Old Sep 12, 2002 | 05:43 PM
dustin's Avatar
Default Re: I know my engine is gone!!! (owen_the_soyboy)
Are you sure you had the cam timing correct... i.e. perhaps you were off a tooth or a few?
Old Sep 12, 2002 | 06:37 PM
Isaac's Avatar
New User
Default Re: I know my engine is gone!!! (dustin)
There had to have been a timing problem. That's the only thing that could've gone wrong. Unfortuantely for me, I and the people helping me out didn't take the necessary precautions, such as checking the timing etc,. I don't know what to say or think, except Thanks everyone.
Old Sep 12, 2002 | 06:39 PM
ynotlim's Avatar
i'm thinking its your timing... its happned to my brother b4
Old Sep 12, 2002 | 09:56 PM
iH8RICERZ's Avatar
did you do a valve adjustment? its required when you switch out your cams w/ bigger or after market cams and cam gears...and to be starting up your car and even be driving it w/ -2 int and -1 exh w/o your cams being adjusted i dont think did very much good for your motor bro. Sorry to hear about your situation..i get **** scared when i mess w/ any internal stuff! good luck
Old Sep 12, 2002 | 10:07 PM
98Psi ITR's Avatar
Default Re: I know my engine is gone!!! (iH8RICERZ)
Who drives off after installing a cam and not checking timing? valve adjustment? wtf? Minutes saves your *** always. Sorry you had to learn the hard way. If any light comes on like CEL or Oil light, stop trying to start the car. Find out what the problem is first otherwise you'll just end up doing more damage.
mecca858
Apr 3, 2015 10:17 PM
Needhelpplease1
Nov 17, 2013 06:59 PM
Tegs0195
Honda Civic (2006 - 2015)
14
Feb 23, 2011 07:09 AM
Isaac
Sep 14, 2002 12:14 PM
Ri5e
Apr 3, 2002 10:44 PM
