No Spark No Start Problem?! NEED HELP!
Old May 14, 2010 | 04:35 PM
dunked dc's Avatar
Icon2 No Spark No Start Problem?! NEED HELP!
Alright i have a 95 integra ls that im rebuilding i put a new motor in it the same b18b1 as came out but rebuilt. My problem is I am not getting any spark?! I checked my dizzy its good threw it on my buddys integra and it fired right up. but on my car im not getting any spark, plugs r new,and wires r new.Any sugjestions or ideas will be appreciated
Old May 14, 2010 | 05:57 PM
Jimmy's Avatar
Global Moderator
Default Re: No Spark No Start Problem?! NEED HELP!
Check all grounds. Is the ECU grounded?
Old May 14, 2010 | 07:04 PM
dunked dc's Avatar
should there be a ground wire coming off the ecu?
Old May 14, 2010 | 08:22 PM
Jimmy's Avatar
Global Moderator
I'm trying to think of what all could be causing the car not to start. Their should be a ground on the thermostat housing. Check all of your grounds. Pickup a haynes/helms manual.. asap. it will help you out tremendously.
Old May 15, 2010 | 04:50 AM
dunked dc's Avatar
i got a haynes and a chilton ha they both send me to the ignition module, but its all good, ground on thermostat is hooked up. idk wats up car has been sittin for days now
Old May 15, 2010 | 05:33 AM
fcm's Avatar
fcm
Old Fart
Do you have power to the distributor assembly, [black/yellow lead] when ign. switch is in run position? 94
Old May 15, 2010 | 06:03 AM
fasthatch95's Avatar
Check your ecu fuse!
Old May 15, 2010 | 06:05 AM
dunked dc's Avatar
yea i removed my dizzy cap and stuck a little light bulb tester in there and it lit up so there is power in the dizzy
Old May 15, 2010 | 06:08 AM
dunked dc's Avatar
all fuses are good
If the ecm fuse is blown im pretty sure the distributor wont spark.
Old May 15, 2010 | 06:15 AM
What about the harness to fuse box, did you tighten those up when you swapped?
Old May 15, 2010 | 06:18 AM
dunked dc's Avatar
ill check...
Old May 15, 2010 | 06:25 AM
I know you said your fuses are good ,im not to positive about 94-97 tegs but my 98 gsr has ignition coil fuse under the dash.
Old May 15, 2010 | 06:27 AM
dunked dc's Avatar
dint find ecm on ether fuse diagrams but checked all fuses and there all good also the wiring to the fuse box under the hood is all snug and good to go
Old May 15, 2010 | 06:31 AM
dunked dc's Avatar
i do not have ignition coil fuse under the dash, its a 95 with a 94 motor if that means anything
Old May 15, 2010 | 07:12 AM
dunked dc's Avatar
it has to be somethin simple if i have power inside the dizzy
Old May 15, 2010 | 09:45 AM
fcm's Avatar
fcm
Old Fart
Do you have power at the injectors, [ign. switch in run] if so check for power at the ECU/ECM IGP 1 and 2, both are yellow/black leads.
If no power on the above, check the PGM-FI Main Relay, injector relays output, yellow/black. 94
Old May 15, 2010 | 11:13 AM
dunked dc's Avatar
i have power at all my injectores
Old May 15, 2010 | 03:19 PM
Jimmy's Avatar
Global Moderator
^ Glad to hear the issue is resolved.
Old May 15, 2010 | 05:47 PM
dunked dc's Avatar
scratch that no spark again?!
Old May 16, 2010 | 07:30 AM
fcm's Avatar
fcm
Old Fart
Have you checked for power at the ECU/ECM IGP 1 and 2 leads? 94
Old May 16, 2010 | 08:31 AM
dunked dc's Avatar
ill check inna bit i got her fired up for about 10 seconds now i got nothing again
thangnhocngheo
Oct 10, 2011 08:27 PM
DJboozeAlot
Jul 16, 2008 11:39 AM
89civicdxracer
12
Feb 2, 2005 05:22 PM
10seceg
Jan 28, 2004 11:28 PM
RussHondaCRXVtec
Dec 17, 2003 10:40 PM
