Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Turbo-boost CR-V 4WD transmission?
Old May 14, 2010 | 11:57 AM
singproinc's Avatar
Icon2 Turbo-boost CR-V 4WD transmission?
I have a 2000 CR-V with the original B20Z block and original 4WD automatic transmission.
I'm considering a turbo boost kit; aside from all the engine considerations, does anybody know how that might affect the original 4WD transmission?
This will be for strictly suburban use, and the turbo will probably only be used to get on the freeway, and leaving my house, which requires turning onto a 60 mph 2-lane highway, going uphill, from a full stop.
Should I consider another alternative for reliability/longevity/safety's sake?
Old May 14, 2010 | 02:00 PM
Deatschwerks's Avatar
Default Re: Turbo-boost CR-V 4WD transmission?
If you aren't going for huge power and are doing just a simple "complete" bolt on kit, there really shouldn't be anything you are planning to throw at it that the transmission couldn't handle. Granted, the Honda autos have never had a reputation for being stout or beefy, but if you are conservative with your tune, you should be alright. The 5-speed would be able to handle quite a bit more, though. Just saying.
Old May 14, 2010 | 02:54 PM
singproinc's Avatar
Thanks for the info. I'm not going for huge power boost; although most of the bolt-on kits are talking in the neighborhood of 350 HP. That's quite a kick up from the original factory spec of around 140.
I'd like to check out a 5-speed, if I'm changing some things out anyway. Is there a particular 5-speed that's a good choice for that engine & frame?
Old May 14, 2010 | 05:59 PM
singproinc's Avatar
Sorry... I just found the CRV 5-speed manual thread here. Looks really intriguing; although apparently hard to find.
turboEMone
Dec 20, 2007 04:29 PM
Trainerindc
Honda Civic (2001 - 2005)
23
Feb 23, 2007 07:04 PM
sepetinswenze
Dec 2, 2006 07:19 AM
do what
Sep 27, 2005 08:40 AM
ceemarun
Jun 15, 2002 11:48 PM
