Idling problem after doing auto to manual help needed!
Old May 14, 2010 | 11:09 AM
JDM-LuxurySport's Avatar
Default Idling problem after doing auto to manual help needed!
Hi everyone i have recently done auto to manual on my 97 integra ls and now im having idling problem. the pointer goes up and down around 2K rpms and then when it warms up then its fine. what could be the wrong?
Old May 14, 2010 | 03:52 PM
Default Re: Idling problem after doing auto to manual help needed!
anyone?
Old May 18, 2010 | 12:53 PM
Old May 18, 2010 | 10:43 PM
Apathy47's Avatar
sounds like all the other idling problems I've seen: dirty IACV and/or FITV.
DIY: Clean IACV - your best bet to your idling problem.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
DIY: Clean FITV - this only applies to you if you have an automatic engine since I know you don't have a 94-95 GSR motor.
https://honda-tech.com/zerothread?id=1564019
Good luck.
Old May 19, 2010 | 11:19 AM
https://honda-tech.com/forums/showthread.php?t=1575913
Good luck.
Thanks a lot but it wasnt doing it before the conversion it started after i did auto to manual conversion. And still using auto ecu and i think thats what causes it.
Old May 19, 2010 | 12:01 PM
Apathy47's Avatar
It would have helped if I knew that...you should be throwing a CEL code for that too.
I did an AT-to-MT conversion too and had idle problems but my issue was a dirty IACV and FITV (auto longblock), it fixed the idle problems but I still have a vacuum leak somewhere.
Old May 19, 2010 | 01:13 PM
tegradb7's Avatar
change ur ecu...90% sure
Old May 19, 2010 | 06:36 PM
sorry i should have said it my bad.
And yes CEL is on other than that cant get the reverse lights work, either the cable from the trans is bad or im doing something wrong with the wiring, also couldnt get the clutch safety switch work either. What did u do for the Reverse lights?
tienzien
19
Aug 10, 2022 07:15 AM
sloaccord97
Jan 20, 2010 05:53 PM
93civicsedan
Jan 23, 2009 11:31 AM
Hatchd
May 14, 2004 10:14 PM
