B18B stalling and running terrible
Hello Everyone,
I have searched and can't seem to find what I am looking for so I am just going to post, so I am sorry if this is a common subject.
I have a 1996 Civic hatch that I swapped a 1994 Integra B18b into. The Integra Donor car ran fine when I pulled the motor. I swapped the B18 into the hatch and it runs horrible. The Hatch has the B18b ecu with a jumper harness to make it OBD1, I put a new ObD2 alternator and Distributer on the motor so the ObD2 Civic harness would fit and changed the injectors and re-wire the 3 pin clip to 2.
Now the problems: When I start it up it runs but stumbles and can't keep an idle. Then if I take it out and run it hard it runs good in the high RPM's but not in the low RPM's. When I stop and let it idle when it is hot the car just shuts off like it has automatic shut off.
I have checked voltage at the TPS and MAP sensors and the ECU and everything comes back fine. Tried a different ECU jumper Harness. I am confused is it the OBD2 Distributer on an OBD1 ECU? Wrong injectors? Bad ECU? PLEASE Help ME,
Thank YOu
Thank YOu
Doesn't seem like a Misfire. The car acts like it is trying to adjust for something. And when it is hot it just shut down like you turned the key OFF but all the ignition and everything is still on just the motor turns off
Anyone? Can I run the OBD2 distributer even though I have it converted to OBD1 and the ECU? Should I be running the OBD1 distributer since I have the car converted to OBD1? Thanks
i think the problem could be with the obd2 parts being ran by a obd1 ecu. i could be wrong but it sounds like it could be your problem. find a obd2 ecu for your car.
Hello Again,
So I bought a new distributer OBD1 and a new ECU and a new Obd2a to Obd1 and put a new throttle body with cold start on and it did NOT fix anything. Does anyone know what is going on here I really need help PLEASE
Thanks
Thanks
xXxHOLYMANxXx
Jul 19, 2012 03:39 PM
zerovandez
11
Feb 7, 2006 09:13 PM
