NEED CAMSHAFT opinion want to chage cams b16 anyone to sell?
Old May 14, 2010 | 04:47 AM
VTIargentina's Avatar
Default NEED CAMSHAFT opinion want to chage cams b16 anyone to sell?
Hi guys!!!
I am really happy with this forum thanks to all of you I been learning a lot about my b16
I have right now ITR intake cam only
I want to change cams to reach 170whp or more
I´m a daily driver
My car pulled 163whp with oem rev limit and 165,3whp with 8500rpm rev limit
I want to know if with crower stage 1 cams I will reach even exceed the 170whp or I will need to get stage 2s
my intend is not to spend a fortune of money cause I live in Argentina and build a car is really expensive in here so I want something reliable!
with stage 2s do I definetly need cam gear or oem timing is ok???? I already have springs that I changed when I did port & polish head work I installed the CTR valve springs on the intake side and the b16a intake springs I put them on exhaust side.
Is it safe that way to use stage 2 cams or I must stick to stage 1 cams?
You have been an inspiration for me!!! you cant get an idea of how much I learnt reading from you!!!
Old May 14, 2010 | 09:05 AM
DDTECH's Avatar
Default Re: NEED CAMSHAFT opinion want to chage cams b16 anyone to sell?
go with the tuner stage 2's or pro1's.. you'll need to upgrade valvesprings tho.
Old May 14, 2010 | 01:40 PM
00Red_SiR's Avatar
All Motor Mentor
I'm also thinking Skunk stage 1 tuner cams at least if not the Skunk tuner stage 2's. Because of where you live being so expensive to be trying a lot of parts, I wouldn't be brave enough (personally) to try the pro 1's. I have no experience with the pro 1's on a b16a so I don't know how well they'd actually do. If you went with the tuner 2's or pro 1's you'd need to upgrade your valvesprings again.
Old May 15, 2010 | 05:18 AM
ALL MOTOR and 00Red SiR thanks BOTH for your opinions.
exactly, where I live it is really expensive you dont get an Idea of how much expensive so I must be wise when building
I don´t want to use Cam gears, that is why I was asking if crower stage 1 or skunk stage 1 will do their job???
I´m in the final line!!! a few more ponies and I am in the 170whp b16 jeje daily driver car!!
or maybe crower stage 2, on their web they say that with oem CTR springs there are no problem
Old May 15, 2010 | 07:26 AM
00Red_SiR's Avatar
All Motor Mentor
I would (and have) personally go with the Skunk over Crower and you will need adjustable cam gears to get the most/best performance out of those cams, even on stock valvetrain.
Old May 15, 2010 | 08:19 AM
ej_b16a's Avatar
stock bottom end B16's like short duration, high lift cam profile is my experience.
So buddyclub 3+, brian crower stage 2 or skunk2 pro 1 would work well for your setup.
Buddyclub 3+ made 173whp in my b16a without tuning cam gears.
[youtube]http://www.youtube.com/watch?v=0AuzX4VcQ_c[/youtube]
Old May 15, 2010 | 08:40 AM
TheShodan's Avatar
Moderator
But would have made more HAD you tuned the gears, I promise you.
Old May 17, 2010 | 05:56 AM
173whp????? that is a hell of power!!! I want to get that power!!!
what else mods do you have??
I´m in 163whp
00_SiR I saw in crower web that stage 2s from them I dont need springs (I anyway bought springs for the intake and put the oem b16 inner springs on exhaust side
so now my inquiry I think it is between skunk2 s1 or crower s2
profile from skunk2 s1 are better than crower s1 but a little less than crower s2...
soooo I am stilll deciding!!!
Old May 17, 2010 | 06:57 AM
GagnarTheUnruly's Avatar
Blox Bs are a cheap alternative to those cams if money is really a concern.
Old May 17, 2010 | 08:30 AM
ej_b16a's Avatar
Other mods were:
0.020" milled head, edelbrock performer X, 68mm tb, dented hytech tri-y header, 2.5" exhaust, shortram+velocity stack and supertech valvesprings/retainers. Had een huge dip around 7000rpm, switched to a SPfab toda header and it felt much better, but hadn't dynod it after the header switch. Camgear tuning would have helped for more power, but I'm now building a B18c engine.
Old May 17, 2010 | 03:10 PM
00Red_SiR's Avatar
All Motor Mentor
He'd need more of a valve spring than he has now to handle those cams.
Pablomg
Feb 27, 2019 04:25 AM
carlossolorzano
May 18, 2012 04:38 PM
walo
May 17, 2010 02:04 PM
ludespeed501
May 24, 2006 01:05 PM
