JDM b18c Type R swap Fuel Pump
Old May 14, 2010 | 12:17 AM
bunnyx's Avatar
Default JDM b18c Type R swap Fuel Pump
I did a b18c type r swap in my 2000 civic ex so anyone knows if i need to change my fuel pump to the ITR fuel pump? I just dont wanna run lean and blow up my motor. anyone know the size of the itr injectors?
Old May 14, 2010 | 12:54 AM
racebum's Avatar
Default Re: JDM b18c Type R swap Fuel Pump
no, and 240cc, the difference is in the tune. the itr injectors are the same as the ls, rs, gsr 96+
if you did the itr swap just use the ecu and injectors the motor came with. you may have wiring issues, then again you might not. i know every detail doing one of these in an integra, in a civic...clueless, no idea wha the wiring is like
Old May 14, 2010 | 01:16 AM
bunnyx's Avatar
I used my stock ex harness and everything plugged in except im going to have to extend the iat wire or just leave it be on my cold air intake pipe. On the civic the iat sensor is on the Intake pipe and on the p73 manifold its on the front above the fuel injectors.
turkdog
Dec 2, 2003 05:41 PM
jeremy.
Sep 29, 2003 05:35 PM
blkrice
Nov 11, 2002 03:27 PM
civichbdx
Sep 13, 2002 09:39 AM
ASR
Feb 20, 2002 09:50 PM
