leak between mc and booster
i have fluid leaking between the mc and the booster whare they bolt together, its ben leaking slowly for a few months and i want to get it fixed, is this just the gasket between them need replaced or is it the mc leaking inside??
thanks, thats what i was planning on doing but i wasnt sure if fluid was soposed to make it to that seal in the first place i thaught there was a diffrent leak behind it
once you start leaking there ur mc will soon be going out, the seals inside on the piston thats inside the mc is the actual seal thats bad.. you can rebuild ur mc but is cheaper/easier to just buy new
eh9deux
17
Jun 13, 2011 07:33 AM
CivHizzle
Nov 22, 2004 07:18 PM
