Transmission whine...need some help.
Old May 13, 2010 | 08:47 PM
Rooftop voter's Avatar
Default Transmission whine...need some help.
A few weeks ago I had a horrible missed shift, and my trans started whining pretty bad. I pulled it out and had my friend who works on trannys inspect it and he ended up replacing all the bearings, and I decided to Have him put in some carbon synchros while it was open. He said mechanicly everything else looked great. Well, the trans is back in and the whine is A LOT better, but I can still hear some whining. I'm not sure what else it could be if the gears are all good and all the bearings are new? Any suggestions on what to try? I'm using regular honda mtf, maybe royal purple or synchromesh to quite it down? Could the actual input shaft be damaged? It was a 3 to 2 shift at 8k rpms, real bad. Seems to shift excellant right now though, and all is good except for the whine.
Old May 14, 2010 | 07:04 AM
Default Re: Transmission whine...need some help.
Bump
Old May 14, 2010 | 04:36 PM
Someone has got to have an idea or suggestion.
Old May 15, 2010 | 10:06 AM
v8 integra's Avatar
i know this might be silly but did he change the input shaft? and yes did he hit it with a hammer cuz that could have killed the bearing during the install. i changed all of mine as well and i have over 200k of abuse and its quite as can be. does the sound go away when you press the clutch? does it come back when you let go? does it wine more as you rev? or drive fast. As to your question yes the input shaft could be damaged but i really doubt it because it would be alot louder if that was the case and you would deff feel it in the shifts. easiest thing you can do is use hondas new mtf witch i like or gm synchromesh. not for nothing how many miles did you put on it so far after rebuild you have to break in the new bearings and change the fluid anyways after a rebuild so it will be a lil whiny. i think you have nothing to worry about it.
Old May 15, 2010 | 03:21 PM
Thanks for your response. No, the input shaft was not changed out. Yes, he did put it on with a hammer and a socket I believe. He usually uses a tool, but he forgot it at work. That said, he was very careful putting it on, and we felt the bearing afterward, and it felt just as slick as it should be (well, as least as slick as it was before he put it on) not sure if you can damage it an not feel it, but it seemed ok. I really only hear it in 4th and 5th gear now if the rpms are lower. I used to hear it in 3rd pretty good too, but since we changed out the imput shaft bearing, I haven't heard it in 3rd. I'm not sure if the sound is there in the lower gears or not, as the engine is lounder and probably drowns the sound out. If I let of the throttle with the car still in gear when I'm driving, the sound will go away, but as soon as I get on the gas again, it will come back. We replaced all the bearings at different times as we didn't think they were all bad at first. We replaced the top end bearing, and a couple more, that didn't do anything, then we replaced a couple other bearings, and that helped slightly, and then this last time we changed everything that was left, and this time it quited everything down a lot, but still not perfect. I have roughly 60 miles on it give or take some. Maybe I'll try some more tranny fluid, but the tranny fluid is Honda MTF that I got new the first time we put in the bearings. I used to use synchromesh Friction Modified, but I can't find it now. I guess I'll do some looking tomorow. Think it just needs broken in more?
Old May 16, 2010 | 02:16 PM
Still looking for more input.
Old May 17, 2010 | 07:26 AM
LambdaJoker's Avatar
Did he replace the throwout bearing? And wat about the pilot bearing? That's the one on the flywheel
Old May 17, 2010 | 08:50 AM
No, I didn't replace either bearing. I doubt the TOB would have anything to do with the sound of the trans while in gear. The TOB only does something when the clutch is depressed. The pilot bearing I don't know about though. I thought that when the Pilot bearing starts going bad shifting gets hard and such, but shifting is just fine. Another thing that leads me away from a pilot bearing is that when I let off the throttle and leave the car in gear, the sound goes away. I would "think" that it would still make the sound if it was the pilot bearing. Anyone else know for sure?
Old Mar 30, 2011 | 04:33 PM
5OHinaEK's Avatar
sounds like a diff bearing ... Let off and it goes away. Get on it and it comes back .. Cant remember if thats a pinion bearing issue or carrier bearing. Should be the same idea as with rear wheel drive but intergrated ....
Old Mar 30, 2011 | 04:38 PM
5OHinaEK's Avatar
dont feel bad........... Mine whines like a blower in first and get less with each gear. Gonna drive it till it blows up lol
Davidss
Transmission & Drivetrain
Jun 12, 2013 08:21 AM
Rooftop voter
Jul 6, 2010 07:16 PM
killerpenguin21
12
Jun 9, 2009 10:18 PM
B16aCRXSi
Sep 15, 2008 07:30 PM
tomu06
Jan 15, 2006 11:30 AM
