vibration or wobble issue
Old May 13, 2010 | 12:19 PM
StayKrafty's Avatar
Default vibration or wobble issue
I'm going to appologize in advance for any spelling errors because I'm posting this my phone.
Anyway, I have an 88 crx si with na jdm d15b swap and an si tranny. When I turn hard to the left I have a very hard vibration or "wobble" in the driverside front wheel. I hear a pop sometimes and then it'll virbate. It'll. Go away if I jerk ther steering wheel left to right. My thoughts are its the halfshaft, I've replaced it 3 times in ghe last 3 weeks, its helped but it eventually comes back. A mechanic at work says it sounds like the axle shaft is slidding out of the cup in that sits in the tranny. If this is the case, how do I go about fixing it? Is there a difference in the axles for the years of the crx? I've been getting 88 crx halfshafts could that be the problem? Any thing would help at this point.
Old May 13, 2010 | 01:07 PM
StayKrafty's Avatar
Default Re: vibration or wobble issue
Also, I guess I should clearify it always vibrates when turning left hard and it'll vibrate going in a straight line til I jerk the wheel
Old May 13, 2010 | 03:17 PM
xalents23's Avatar
You check your front wheel bearings? Jack up your car in the front and grab your tire at the 9 and 3 o'clock position and shake it back and fourth. And the 12 and 6 o'clock position. If you wheel shakes when you do this your wheel bearings are bad. Try both your right and left front wheels.
Old May 13, 2010 | 03:21 PM
StayKrafty's Avatar
You mean shake down? I've done all that, its all pretty solid, if I jack the car up nothing seems wrong at all. I'm. Going to have to check it when my front end shakes again. Any other ideas?
Old May 13, 2010 | 09:04 PM
StayKrafty's Avatar
No one?
Old May 13, 2010 | 09:42 PM
civichb20's Avatar
PM Garage
call your local parts store and ask them to check part number thru the year to see if you get a different part number. Also check you wheel bearing by lifting car up off the ground and then check for play in front wheels. check you suspension to see you also have any play and check bushings etc. Try some white quick dry paint or marker and paint all bolts and where they seat for position or movement. gl.
Old May 13, 2010 | 10:08 PM
StayKrafty's Avatar
I'll try the paint idea. I checked part numbers and they were the same. Curious though, why are the clutches for the 88 si's different than the 89-91 si's
Old May 14, 2010 | 07:07 AM
StayKrafty's Avatar
Paint idea didn't work an other help?
Old May 14, 2010 | 07:27 AM
sfetech01's Avatar
if axels slipping in and out, check the clip on inner shaft if it checked out o.k. problem would be in tranny, also check your trans.mounts.
Old May 14, 2010 | 09:20 AM
StayKrafty's Avatar
Kniow the clip is in there. I'll check out the tranny mount
MISTAGLOCK
Aug 19, 2010 08:28 PM
buzlink
16
Oct 18, 2007 07:41 PM
crxaddikt
Sep 14, 2006 09:27 AM
sohcvtec66
Feb 4, 2005 06:02 PM
