Rear sway bar links
Old May 13, 2010 | 07:11 AM
HitF8's Avatar
Post Rear sway bar links
Vehicle: 1992 civic hatch Si
When I bought this car it had a rear sway bar and im pretty sure that the Si didnt come with a rear sway bar stock so I am assuming its from a 94-01 integra. My problem is that i bought some Blox rear lower control arms but I cant continue to use the sway bar. The links arent long enough to fit in the hole in the control so i was wondering if anyone else has run into this problem and what did you do to fix it. I was thinking about trying to find some universal links if I can find them. Any info will help.
Thanks
Old May 13, 2010 | 07:36 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: Rear sway bar links
Believe you'll need 99-00 Si endlinks. The 92-95 Civic and Integra endlinks are shorter, and won't reach properly to the 99-00 Civic mount location. A majority of the aftermarket LCAs I've seen have the endlink mount in the EK location, including (I think) the Blox ones.
Now, the Si links are rather expensive from Honda. I bought the Blox nonadjustable endlinks, which are very similar to the Si links but considerably cheaper.
Link: http://www.jhpusa.com/store/pc/viewP...idcategory=169
Old May 13, 2010 | 07:45 AM
HitF8's Avatar
Sweeeet man thanks for the info!
Shaguar47
Feb 25, 2007 05:16 PM
Santys EK
Aug 12, 2006 07:51 AM
B18C1SI
May 5, 2006 02:24 AM
jdmstreethatch
Nov 11, 2004 12:20 PM
Amuse9
Dec 30, 2002 12:48 PM
