over heating problem
Old May 12, 2010 | 09:18 PM
snowman2876's Avatar
Default over heating problem
well basically my car will run hot when cracked fans dont come on i liet this sit and nothin but when i just turn the key a bit( not to Crank) my fan comes on.
any idea? its messin with my head big timee
Old May 12, 2010 | 11:32 PM
hatchet_honda's Avatar
Default Re: over heating problem
HOT WHEN CRACKED WHAA?? is the fan coming on after youve drivien the car and just turning the key on?
Old May 13, 2010 | 09:39 AM
D16SiHatch's Avatar
op: i have no idea what you're trying to say.
Old May 13, 2010 | 10:14 AM
zcrx_si's Avatar
I think he's trying to say that when he turns the ignition on his fan starts up, but if he actually starts the car, the fan won't kick on and it overheats.
Then again he could be saying that when he's hot, he lights up a fat one, smokes some crack, and sits in front of the fan.....
Old May 13, 2010 | 10:25 AM
ninty1civic's Avatar
^ x2
Old May 13, 2010 | 11:56 AM
what im sayin that when when i turn the ignition my fans come on but if iactuallyu start my car they turn off
Old May 13, 2010 | 02:07 PM
lunalink's Avatar
^ thats because theyre not going to be on 24/7 they only come on when the FAN SWITCH reads the temperature is getting hotter and runs current to the fans which in return turns them on!
if you car doesnt do this after a good amount of time driving you need to replace your fan switch ( might as well change the thermostat)
Old May 13, 2010 | 02:40 PM
4g4dcruisin's Avatar
Thats true, but that doesnt explain why the fan comes on in the ACC position. The fan is not powered this way.
Old May 14, 2010 | 12:50 AM
bump
Old May 14, 2010 | 08:55 AM
very true...tis a mystery
Old May 14, 2010 | 10:20 AM
lunalink's Avatar
check you wiring maybe theyre all Fukd up ? lol
91b18a1ls
Oct 15, 2011 04:24 PM
hangac1093
Jan 26, 2006 06:28 PM
FONK
Jan 11, 2006 08:48 PM
Mrob91GS
Nov 28, 2004 07:12 PM
cr00klyn718
Sep 30, 2002 09:27 PM
