Oil in Spark plug chamber.
Old May 12, 2010 | 06:11 PM
erik_mullen's Avatar
Default Oil in Spark plug chamber.
I pulled my plug wires and there was lil pools of oil in 3 of the chambers, i got all of oil out and clean them out and drove fer a bit and then checked again, the oil is leaking back the upper plug o rings, they feel old and torn, i ordered valve cover gasket and 4 upper o rings for the chambers, you guys think that will do it for the leaking
Old May 12, 2010 | 06:46 PM
Weakbyyou's Avatar
Default Re: Oil in Spark plug chamber.
you have a factory valve cover?
ricebike's Avatar
yes
Old May 13, 2010 | 07:49 AM
yes factory valve cover.
Old May 13, 2010 | 08:17 AM
shortlid's Avatar
there a o-rings at the top of all spark plug tubes. The ones on the leaking tubes must be damaged or worn out
Old May 13, 2010 | 08:34 AM
GhostAccord's Avatar
What make model & year Accord do you own?
The Non VTEC F22A1-6 and F22B2 have a second set of o-rings that can leak oil as well.
Yellow = Upper spark plug tube seals
Red = Lower spark plug tube O-rings
If you own a 90-93 F22A1-6 or 94-97 F22B2 and see that the oil is still leaking in after you replace the upper seals. You may want to remove your rocker assembly and replace the lower seals.
Old May 13, 2010 | 09:45 AM
94 accord ex-r with Jdm h22a Swap, only 3 outta the 4 chambers had a small deposit of oil, clean them all out and drove for a bit and pulled them again and felt those o-rings seals with my fingers and there was small amounts of oil coming from the seals so im taking it that there worn out? what you guys think
Old May 13, 2010 | 11:25 AM
clowery89's Avatar
wow thanks for posting that i have replaced the upper and it still leaked and i just said **** it and gave up but i came accross this and you are now my god ......
Old May 13, 2010 | 11:46 AM
Originally Posted by erik_mullen
94 accord ex-r with Jdm h22a Swap, ....
This is helpful information.
..... only 3 outta the 4 chambers had a small deposit of oil, clean them all out and drove for a bit and pulled them again and felt those o-rings seals with my fingers and there was small amounts of oil coming from the seals so im taking it that there worn out? what you guys think
Yes, replace those worn out seals and you should be good to go! The H22 only has the upper tube to valve cover seals so no need to worry about secondary seals.
Old May 13, 2010 | 12:10 PM
Thank you very much friend!!
Old May 13, 2010 | 06:49 PM
quickster's Avatar
check your pcv valve too. that 3rd chamber can get oily if its not working proper.
Old May 14, 2010 | 01:12 PM
Ok so I bought all four upper spark o-rings and a new valve cer gasket, when I was there I asked them If i would need to put some Rtv sealant around o-rings or around the valve cover gasket and he told me they both go in dry with no kind of sealant, any help would be great also the valve cover bolts 7lbs for retightening>>?
Old May 14, 2010 | 01:31 PM
Here are the tq specs and recommended locations for the use of some RTV sealant (liquid gasket)
Old May 16, 2010 | 05:36 PM
quickster's Avatar
Yea 7lb sounds right, no more than 9. just make sure not to overtighten or you will strip them easily.
Old May 16, 2010 | 06:43 PM
And No sealant on the o-rings for sparkplug chamber
Old May 16, 2010 | 09:01 PM
tsunami604's Avatar
how hard is it to replace the second set of seals? simply remove the rocker arm assembly, replace seals, and retorque rocker assembly?
Old May 17, 2010 | 02:35 AM
Pretty much, just make sure that you remove the assembly all in one piece. Or else you will be putting together a puzzle and not knowing what rocker goes where.
Do you have a shop manual?
Old May 17, 2010 | 05:24 PM
fleetw00d's Avatar
You should back off the valve adjusting screws to unload the rocker arms before removing the rocker asembly. After reinstalling and torquing the rocker assembly, adjust the valves. Get at least a Chilton or Haynes manual for proper torque and sequence.
Old May 17, 2010 | 05:25 PM
Buddhamania's Avatar
Great info there, I was having the same problems and now I dont.
Old Jun 7, 2010 | 07:41 AM
CRZ1's Avatar
GhostAccord,
For 97 accord LX, the lower o-ring (red inyour picture) in http://www.hondapartsnow.com/online/...er%20Head%20(1) is part # 19, 91301-PT0-003
I can not find the top o-ring, do you know what is the part number? Are top and lower o-ring the same?
Thanks in advance.
Old Jun 7, 2010 | 07:56 AM
Personally I've only ever ordered them as part of the valve cover gasket set.
Here are the numbers I found;
Valve Cover gasket set - 12030-PT0-000
Individual part numbers;
Upper tube seal - 12342-PT0-000 x4 (aka Head Cover Gasket B)
Lower tube o-ring - 91301-PT0-003 x4
Old Jun 7, 2010 | 09:16 AM
CRZ1's Avatar
Thanks a lot!
Old Jun 7, 2010 | 10:10 AM
NP
Old Jun 8, 2010 | 08:00 AM
ChevelleSSLS6's Avatar
If you're going to bother the lower seals, may as well swap in a cam in the process...
Old Jun 8, 2010 | 08:01 PM
accord_raffi's Avatar
swapping the cam could be an unnecessary cost depending on the op's goals.
