need help with slave cylinder and clutch line.
Old May 12, 2010 | 08:38 AM
SDx1990's Avatar
Default need help with slave cylinder and clutch line.
my friend is doing a b series swap on his d series. and his clutch line where the hose is at. and the slave cylinder line where the tranny is at. it look like it need 12inche of line or so to fit it. can somebody help please. what the problem why is it so far apart from the clutch line hose to the slave cylinder.
thanks~
Old May 12, 2010 | 09:19 AM
SDx1990's Avatar
Default Re: need help with slave cylinder and clutch line.
anybody? need help.
Old May 12, 2010 | 09:45 AM
lsvtechatchy's Avatar
on my b-series my clutch master cylinder is in the back upper corner of the drivers side and the clutch line extends around the backside of the motor, under the intake and around the front of the motor to the slave cylinder. (i just replaced mine) its about a good 4-5 feet of line. i dont know if this helps
jdm kidd
Jan 15, 2011 06:07 AM
rhdins
Nov 3, 2009 03:22 AM
clipse9784
Dec 27, 2004 12:12 PM
