can tunning rich cause rings to flush out
Old May 11, 2010 | 10:38 PM
eg:R's Avatar
Default can tunning rich cause rings to flush out
As title, can a rich tune for wot (10's a/f) cause the piston rings to prematurely go bad? What are the target wot a/f for most of the common gas used today (91, e85, c16, methonal, ECT...) most people say 11.8 a/f. Is this target a/f okay for all the gas type.
Old May 12, 2010 | 08:44 AM
HiProfile's Avatar
Default Re: can tunning rich cause rings to flush out
The problem with 10's is that 10:1 is the lower limit on a few widebands. Meaning 9:1 or lower won't show as "too rich", it will just stay at 10:1. Alcohol fuels can run very rich because they don't wash away oil easily. Gasoline does, so running very rich can ruin your rings.
Different fuels will want different AFR's. C16 and E85 can be run leaner than pump gas, while meth is usually run rich. This takes into account lamda, or "perfect combustion" for each fuel.
Old May 12, 2010 | 12:39 PM
eg:R's Avatar
What is consider leaner than pump?? With
e85 andc16.. 12's a/f? Can pump gas with full meth injection and pump gas91 with fullmeth injection have the same target a/f? What wot target a/f will be good for each??
Psychoteen101
Sep 9, 2016 10:47 AM
terbear4god
Jan 25, 2012 07:33 PM
eg:R
May 15, 2010 01:08 PM
Silvertc
Feb 16, 2010 12:56 PM
thegeezerkid
Apr 2, 2009 06:24 PM
