17x7.5 +45 offset wheel fitment?
Old May 11, 2010 | 06:35 PM
twkdCD595's Avatar
Default 17x7.5 +45 offset wheel fitment?
Putting some 17x7.5's with a +45 offset on my car cause I have them sitting here and wanting to change up the look. Anyone ran this size with per say a 225/45/17 tire?
By the math they should be a tight fit but I can only do so much with the size numbers. Anyone running this combination and can confirm they fit?
Old May 11, 2010 | 06:49 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: 17x7.5 +45 offset wheel fitment?
Tight fit how? I don't understand what your concern is. Those wheels aren't very wide and have a high offset.
Old May 11, 2010 | 06:53 PM
twkdCD595's Avatar
Front measures out pretty good but on the back I am worried about the tire very close to rubbing agianst the vertical arm part of the knuckle that goes up to the ball joint. Number 2/3 in the parts diagram below is the knuckle for reference.
http://www.hondaautomotiveparts.com/...REAR+LOWER+ARM
This is on a 95 ex sedan btw with Ksports coilovers, maybe a 2.25 or 2.5 drop.
Old May 11, 2010 | 07:20 PM
Blazin Si's Avatar
Loved
Community Favorite
Originally Posted by twkdCD595
Front measures out pretty good but on the back I am worried about it rubbing agianst the vertical arm part of the knuckle that goes up to the ball joint. Number 2/3 in the parts diagram below is the knuckle for reference.
Oh I see what you're saying. I can't see how it would be a problem. You should test fit them and find out for sure.
Old May 11, 2010 | 07:25 PM
twkdCD595's Avatar
I measured it up best I could with the car on jack stands and there is very little clearance there. When back on the ground or with the suspension moving up and down when driving, I am not sure if I will have more or less clearance in that area.
Thats why I am posting here, I dont want to spend 600 on tires to test fitment cause I will lose my *** trying to resell them if they dont fit. Thats why I was hoping someone here can confirm or deny if they clear.
Old May 12, 2010 | 07:26 PM
twkdCD595's Avatar
No one?
Old May 13, 2010 | 11:35 AM
unscenecd7's Avatar
on a 17x7.5 best bet is to run a 215/45/17.
Old May 13, 2010 | 05:01 PM
hb_guy's Avatar
i run a 235/40/17 with +42. dont know if it helps
Old May 14, 2010 | 06:30 AM
Andryzzle's Avatar
I ran these with 205/45/17 and no issues. Can't speak for the wider tire though.
Old May 14, 2010 | 08:33 AM
ilikehonda's Avatar
get a smaller side wall. do a 215/35
Old May 14, 2010 | 09:20 AM
twkdCD595's Avatar
I need the width and height to at try to have as much traction as I can muster on these wheels instead of my 15's. This is a turbo car and these wheels are just something I am bored and trying for giggles.
I actually more like the OEM wheels than most anything since I like to keep my car low key sleeper look since basically its all stock looking other than a bit of a drop.
As an update though, I ordered the 225 45 17's already since I am impatient. BFG drag radials for front 2, some brick hard eagle f1's for the rear 2. Will update when I fit them tonight and put the car back on the ground.
Old May 14, 2010 | 09:53 AM
Andryzzle's Avatar
if they rub on the inside you can grab some slight spacers since you said you aren't that low.
Old May 15, 2010 | 08:12 AM
twkdCD595's Avatar
Well they do clear the suspension in front and rear but WOW its close in the rear. Maybe 3/4" of clearance between the tire and that arm that comes from the knuckle. I put a block and jack under the tire while on stand and raised the tire up to see if I maintain that gap or it closes up as the suspension moves... looks like I maintain that gap all the way up.
A short drive around and a check on the tires for rub marks should tell me for sure but it looks like its ok... although very close clearance in the rear. Also need to check the lock to lock turning to see if the front drag radials are going to rub.
Old Sep 24, 2010 | 12:44 PM
twkdCD595's Avatar
Just as a final update so if anyone ever stumbles across this, they clear and do not rub. If you turn completely lock to lock they will bearly touch the radius rod from the front crossmember.
However I have ESP traction bars on mine so maybe stock cross member and radius rods would be ok.
I rarely turn like completely lock to lock and thats what it takes to rub so for me these fit about perfect.
Old Oct 13, 2010 | 08:45 AM
BaltMAN's Avatar
Do you have any photos of your rims/tires? I'm thinking about using 225/45-17 on my car.
Old Oct 13, 2010 | 10:06 AM
Brad_and_the_acc's Avatar
thread is useless without pics.. You should know that twkd.
El3ments
Mar 13, 2009 11:36 AM
Accord1234
Jan 31, 2008 02:50 PM
bo0st lee
Acura TSX
Jun 1, 2007 10:45 AM
honda95civic
Mar 27, 2005 08:10 PM
Mr. Vapor
Jun 6, 2002 07:36 PM
