rear disc conversion.. what prop valve
i have a dx coupe and im getting ready to do an si rear disc conversion, ive already grabbed the entire trailing arms with lca's and compensator arms with all bushings and of course the disc assembly plus e brake cables. i also have an integra master cylinder and brake booster. ive been getting mixed answers from the internet about which prop valve to use and i looked up the part numbers on acura oem and the dc integras non abs vs. abs proportioning valve seem entirely different... could i use one from a DA integra?
sorry i forgot to clarify that i have a 95 without abs http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT i ended up buying this
i bought one like that but not that specific one... im just ganna buy some complete ex knuckles, hopefully today from a local if when i see em theyre not in bad shape.. then i can use this prop valve? http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWNX:IT
Below is a list of what i've found, i've bolded the 3040 prop valves, the others in the list are all 3030.
46210-SR3-962 VALVE ASSY., DUAL PROPORTIONING 1995 CIVIC Si
46210-SR3-962 VALVE ASSY., DUAL PROPORTIONING 1992 CIVIC Si
46210-SR3-962 VALVE ASSY., DUAL PROPORTIONING 1992 CIVIC DX (sedan)
46210-SR3-962 VALVE ASSY., DUAL PROPORTIONING 1994 CIVIC LX
46210-SR3-013 VALVE ASSY., DUAL PROPORTIONING 1992 CIVIC CX
46210-SR3-013 VALVE ASSY., DUAL PROPORTIONING 1994 CIVIC DX (hatchback)
46210-SR3-013 VALVE ASSY., DUAL PROPORTIONING 1994 CIVIC VX
46210-SR3-013 VALVE ASSY., DUAL PROPORTIONING 1994 CIVIC DX (coupe)
46210-SR3-013 VALVE ASSY., DUAL PROPORTIONING 1994 CIVIC EX (coupe)
ok well then if i just upgrade to gsr fronts the 40/40 would be the correct prop valve right cause i am in process of doin all my tech research on what diff honda/acura brake parts performance is in diff combo's since i work at in a race shop i can test diff parts
looks like so far a 1" master/booster, Gsr fronts, Ls rear is best setup for a DD using stock parts but have a couple other parts to test psi they can put out
Hmm, after doing some research it would seem that you are in fact correct.
Again, after some research it turns out they are the same, weird when you consider that the front brakes on the '94 - '95 models were larger EX style brakes.
so i bought a pair of ex knuckles and i just ordered some replacement rotors cuz the ones it came with are looking kinda rusted.. heres my final parts list.. please tell me if everything will work out alright with this setup paid a total of $280.. too much?
si rear trailing arms with si ebrake cables,
ex knuckles,
integra 4040 prop valve,
integra brake master cylinder and brake booster
ex knuckles,
sinyce
Aug 2, 2016 10:48 AM
WillyD
Sep 6, 2012 01:19 PM
mofo951
Mar 7, 2009 03:36 PM
