Torque steer on 96 EK
Old May 11, 2010 | 05:08 PM
Reyracer19's Avatar
Default Torque steer on 96 EK
Details..
Suspension is stock minus Koni shocks and ebay coil overs,
Engine is bone stock
Recently had the alignment done and noticed my steering off center to keep the car straight, but now i'm also noticing that under medium throttle the car pulls to the right and at higher speeds when you give it some gas it will shake a bit on the front right side.
What could it be?
Any help would be appreciated as I have a long drive towards the end of the month to get some interior work done.
Old May 11, 2010 | 05:20 PM
b20hatchek's Avatar
Default Re: Torque steer on 96 EK
shaking from the front end is a sign of bad struts
Old May 12, 2010 | 05:17 AM
Reyracer19's Avatar
The strut is brand new, and it doesn't happen while coasting or breaking, only during medium -heavy throttle.
I suspect maybe some suspension component is either loose or broken but could it be an axle issue or maybe a motor/tranny mount?
Old May 12, 2010 | 05:53 AM
b20hatchek's Avatar
yeah either one of those can do it also
Old May 12, 2010 | 06:50 AM
alphalanos's Avatar
Sounds like they didnt straighten the wheel when they aligned the car. When the car is aligned properly, the wheel should be straight when the car goes straight, on a flat surface. As for the shaking, jack the car up and check bushings, wheel bearings, loose bolts, etc.
Old May 12, 2010 | 07:38 AM
Reyracer19's Avatar
Yeah the alignment is my first issue of concern. But just to be safe over the weekend I will jack up the car and look around at some of the components mentioned above. This time i'll try a different shop to do the alignment.
mrbasshead305
Suspension & Brakes
Mar 20, 2013 08:35 PM
204snic
12
Jan 7, 2010 04:08 PM
bbbleondacomeup
Mar 11, 2008 01:08 PM
t3ddyb3ar21
10
Jan 30, 2006 12:46 PM
dohcroc
Jul 4, 2004 09:59 PM
