Fuel efficiency
Two parts:
1. I was wondering what the big deal about these 'cold air intakes' with their air filters are? If it increases MPG how come they're not stock?
2. Also, with rising gas prices, does putting better gas in the car give better MPG over the cost?
Car: 1998 Honda Accord LX 2DR AT
"better gas" ? If you mean higher octane, then no, it is not "better gas" it allows for higher compression before combustion. It will serve no benefit in the low compression motor you have.
Cold air intakes come with risks, please just do a search. Both of your questions are answered all over Google.
To gain tangible fuel efficiency, do a search for gas mileage threads in the Accord section, there are plenty of suggestions.
kitt, my car is a 1998 Accord LX 4 DR MT.
As far as a new intake helping your MPG, its debatable. I have one (puts the cone filter right where the air box is on your car) and it definitely makes it sound better, but what you really need to focus on is the filter. I changed to a K&N and noticed a slight bump in MPG (this was on the stock airbox and I got one on the new intake).
Just stick with regular gas. As TheMuffinMan said, higher octane does NOTHING for our engine. And while we are on the subject of engines...
Make sure you keep up on maintenance! Use quality oil, keep up on tranny fluid changes, use injector cleaner every once in a while (Lucas, Redline, and Techron all do the job nicely), change/clean the air filter, etc. All of this stuff helps keep your gas mileage up.
Good luck!
Good luck!
^^^ + New plugs, wires, cap & rotor and maybe even a new coil if yours is still the original. I added an extra 100km /tank of gas by doing a full tune-up and replacing my 1996 coil and ignitor.
Ok, thanks guys. I've read keeping the air filter clean helps with the MPG. I'll consider purchasing a K&N filter to replace my stock filter once it gets dirty. Also I'll stick with the low octane gas.
I guess I'm not pro enough to do the nitty gritty tune-ups and upgrades, but I'll keep up with the maintenance.
Do as the others said.
But there IS a difference between good and bad gas. Personally, I ONLY use BP, Shell, and Mobil. I don't care if they are a few miles out of the way, I refuse to use gas from no name places like, Casey, Freedom, Qik n Easy, Thortons, and etc. There is a difference as I have compared multiple times before.
Personally, the majority of the time I use BP but every 3 fill ups I will switch and fill up with either Shell or Mobil.
Two parts:
I saw a post on here some time ago with a dyno chart from AEM Cold air intake, and the horse power actually decreased below 3k RPM and you get gains only in the higher RPM (where I practically never rev to).
A stock size K&N filter might be the best. Be sure to keep K&N oiled though, because it traps dirt with the oil using static electricity rather than a purely physical barrier from the stock filter.
1994 accord got 27 average 34 highway 130hp i4 2880 lbs 4spd auto
1998 accord got 25 average 33 highway 200hp v6 3197 lbs 4sp auto
2002 cl typs gets 24.7 average 31 highway 290hp (headers) v6 3515 lbs 5spd auto
gaining 160 hp, 2 cylanders, 625 lbs but loosing only 3mpg = win in my book cause i keep my right foot out of the throttle.
gadawg31
19
Sep 24, 2012 05:16 PM
YNG
13
Aug 31, 2008 05:45 AM
JasonLX
Aug 20, 2005 12:19 PM
SiMateoAko
28
Jul 1, 2005 12:14 AM
