aftermarket throttle body problem
Old May 10, 2010 | 10:14 PM
kornkid21792's Avatar
Default aftermarket throttle body problem
ok sooooo i purchased a 70 inlet 68 outlet omni power throttle body. its on a stock manifold havent had time to portmatch. anyways the idle is all wierd. it goes up and down when you start the car not to bad like 500 too 700 and it is not constant. but when i am driving and put it in neutral the rps go up to 1500. and stay there till i come to a complete stop then it stays at about 900 i am really lost as to why it would do this any help would be much apperciated
Old May 10, 2010 | 10:24 PM
Lude Acts's Avatar
Default Re: aftermarket throttle body problem
Vacuum leak? Are you sure the TB gasket seated all the way? Maybe the TPS is bad on it also. Just because it's new, doesn't mean it can't be broken. Get a volt meter and check the Helms for the proper procedure on checking the TPS.
Old May 10, 2010 | 10:27 PM
checked vaccuums they r good. and im pretty sure the gasket sealed it appears it did. i used the tps from my old stock throttle body could that cause the problem?
Old May 10, 2010 | 10:52 PM
Skwaro's Avatar
IACV cleaned? If yes follow these steps:
disconnect IACV
set your idle to 550RPM (on warmed up engine)
reconnect IACV
reset ECU
start the engine and let it work for a while to stabilize idle
After that everything should be fine.
Old May 11, 2010 | 06:38 AM
what does unplugging it do,? and wouldnt reseting the ecu ruin the whole point of unplugging it
Old May 11, 2010 | 10:46 AM
Rosko's Avatar
Did you use the gasket that came with it or did you use a stock gasket? Sounds like you got a small leak somewhere.
Old May 11, 2010 | 12:19 PM
Skwaro's Avatar
Nope, if there is no leak this procedure should work. You have to disconnect IACV to set up your idle mechanically (you have to switch off radio, a/c and so on), then you can connect IACV to teach ECU how much air must be added through IACV to the intake when switching on e.g. A/C to prevent engine from dying.
Old May 11, 2010 | 05:27 PM
i unplugged it started the engine cel came on turned it off reset ecu plugged iacv back in no changes
Old May 11, 2010 | 06:26 PM
Tunerguy1989's Avatar
Would that procedure work if my idle acts up when I turn on my A/C. My car idle perfect but when I turn my a/c on it randomly spikes then stabilizes. I plan on tuning my ECU soon could tuning it in a certain way fix my idling issue?
Old May 11, 2010 | 09:02 PM
i used the gasket that came with it
Old May 11, 2010 | 10:56 PM
Skwaro's Avatar
At first you didn't answer if IACV is cleaned.
Was the engine warmed up? Did you adjust idle? CEL shows that you disconnected IACV, don't worry about this.
You should reconnect IACV after switching off the engins but before ECU reset.
If you still have the problem then most probably you have a leak somwhere.
Old May 11, 2010 | 10:57 PM
Skwaro's Avatar
If everything works properly (IACV, no leaks) lowering IACV compensation should help...
Old May 12, 2010 | 03:06 PM
duanes's Avatar
Once car is warmed up, turn of ac and all electrical stuff. Then unplug IACV. Your idle should drop and be pretty steady.... adjust idle speed with the idle speed screw (NOT by adjusting tension on the throttle cable. It should have a small amount of slack). Idle should be about 550 or so.
Plus IACV back in and idle should be steady at 850-900 or so. If the idle was steady, but not moves around too much, then the IACV needs to be cleaned as it is sticking.
I have never had to unplug the battery (4th Gen). The engine light resets for me when the car is turned off.
Oh - if idle is moving around a bunch with the IACV unplugged, then either the cold air valve is loose/leaking or you have a vacuum leak. The CAV is the most likely as a vacuum leak usually just makes the engine idle too fast and you can't seem to slow it down enough, but doesn't normally hunt around. The CAV has a thermal wax plug in it that vibrates if it is loose and causes all sorts of idle problems.
Old May 12, 2010 | 03:16 PM
sirb16a's Avatar
^^^^^^^yup^^^^^
Old May 12, 2010 | 05:09 PM
autoluder's Avatar
try also bleeding the coolant at that bleed valve on top of the thermostat.
Old May 12, 2010 | 09:11 PM
Skwaro's Avatar
There is no idle screw in Omni Power TB, you have to use the screw blocking butterfly plate below the cable mount.
Old May 12, 2010 | 10:06 PM
thanks guys for all the help.
bled the coolant
unplugged it and that didnt help
iacv is clean as a whistle.
how do i lower the compression on the iacv
and why would that needed lowering
maybe differnt circumstances because of aftermarket throttle body?
d-it-big99
Oct 13, 2010 01:56 PM
chiefb26
22
Apr 18, 2008 05:32 PM
Bakersfieldgsr
Nov 12, 2007 03:34 PM
PowderB16
Jul 16, 2004 08:34 PM
rasta420
Apr 22, 2003 01:02 PM
