Finished my Y7 swap, started and now code 7
Old May 10, 2010 | 09:31 PM
Fo-Do Fanatic's Avatar
Default Finished my Y7 swap, started and now code 7
I just finished my Y7 swap today. I'm using all my OBD-0 stuff (i.e intake mani, dizzy, throttle body, alternator and header.
I started it up for the first time and my car immediatally jumps to 3500RPM and the tach bounces around a little bit at around 500RPM incrimants. Could my TPS have taken a **** while doing this? My car never did this before so I'm kind of lost. I know code 7 is throttle angle but what all could cause this?
All help/insight/suggestions/etc... is appreciated.
Old May 11, 2010 | 12:00 AM
netfreak's Avatar
Default Re: Finished my Y7 swap, started and now code 7
Silly question, but have you double checked everything is hooked up again? I literally did the same swap last week and I had no issues on first start. Maybe grab another throttle body from the junkyard and see if it makes any difference.
Old May 11, 2010 | 07:17 AM
I double and tripple checked everything. I made sure the prongs were straight on the TPS. When I first tried to plug it in the prongs were bent, but I didn't think that would make any difference. All three prongs are there and the wires on the female side of the plug are nice and snug.
Old May 11, 2010 | 09:24 AM
Do you guys think it'd be okay to use my old TPS sensor off my old DPFI motor and put it on my MPFI throttle body or could I run a Z6 throttle body?
Old May 11, 2010 | 02:09 PM
I tried my old TPS just now and no go. I'm realllllly stuck. Would it be better just to go pick up a whole complete z6 intake mani?
Old May 11, 2010 | 02:54 PM
BTRacing's Avatar
Did you calibrate you TPS?
Old May 11, 2010 | 02:59 PM
Even before I messed with it it still had a ridiculous high idle and was so sporadic and miss firing and throwing code 7. How the hell do you calibrate it when it's rivited to the the throttle body?
Old May 11, 2010 | 03:20 PM
ByonSho's Avatar
Clean out the idle control valve
Old May 11, 2010 | 05:48 PM
BiG ChOr!Zo's Avatar
calibrate your tps or pick up another one from the junk yard...a dpfi tps wount work on a mpfi manifold since they spin in opposite directions...!!!
Old May 11, 2010 | 10:03 PM
No wonder the litle prong snapped when I took it off to inspect My junkyards don't have any 88-91 civic/crx Si's around here. Unless there is another obd0 mpfi throttle body I can use that'll work just fine?
Old May 11, 2010 | 11:57 PM
si
Old May 12, 2010 | 09:01 AM
si
Good luck to me finding one
Old May 12, 2010 | 09:39 AM
D16SiHatch's Avatar
i would check for a vacuum leak. its quite unlikely that enough air could get past a closed butterfly valve to allow the engine to rev that high.
Old May 12, 2010 | 10:13 AM
lunalink's Avatar
check your TPS with a multimeter. it has to be @ .50 with open ignition. ( not the car on lol)
and you can adjust it by loosening the screws and moving it a bit until its at spec..
and I believe any MPFI TPS will work but not 100% sure.
Old May 12, 2010 | 03:04 PM
Well I got a new si throttle body today, put it on and started it......but then the same thing happens. Goes to 4k and misfires and ****. But now it's not throwing the code. So atleast I'm getting somewhere. I loosened the screws and tried to adjust it by ear but to no avail, NOTHING. Sameeee ****.
Old May 12, 2010 | 03:36 PM
Matt91's Avatar
firing order right??, all spark plug wires are actually plugged in to distributor??
Old May 12, 2010 | 03:37 PM
BTRacing's Avatar
^^^^ JUST LIKE LUNALINK SAID
turn engine off. key in on position. black multimeter lead goes to a chassis ground. red goes to middle wire on tps sensor.
you need to "back probe" the tps plug while it is still connected to the tps sensor. you need to basically just shove the tip of the lead into the back of the plug until you get a reading.
set the multimeter to "V" the one with the dash and dotted lines not the squigly and place the selector on 20.
with the throttle closed, multimeter should read 0.5, wide open it should read 4.5 volts. get as close to these numbers as possible.
Be careful and patient. DONT do it when the engine IS HOTT.
try adjusting the idle screw and clean the throttle body really good with carb cleaner...!!!
Old May 12, 2010 | 05:57 PM
Marcos Barrios's Avatar
your intake manifold did get a new gasket put on right?
and you cleaned the intake and head before putting this gasket on right?
also your tb has a gasket on it right?
Old May 12, 2010 | 09:38 PM
This is what I'm about to do right now. My buddy put the intake mani on before the motor went in and I didn't see the condition of the gasket on there if there was any. I picked up a new TB gasket and ANOTHER new I/M gasket so I'm going to go clean away right now. Wish me luck!!!!
Old May 12, 2010 | 11:33 PM
The little bastid started!! Yesss!! Now just a couple little quirks to start out and I'll be good to go!!!
Old Nov 5, 2010 | 07:56 AM
Bumping my old thread, but I'm still getting code 7. I'm kinda stumped. I'm going to double check and see if my wires have power and a ground, using a multi-meter. But I've boughten another throttle body with a known good TPS so I'm perrrrty sure it's not that. I've resoldered all the wires and re shrink wrapped them as well. I'm thinking maybe I have a bad connection with TPS signal out wire, the red one. I'll check that by looking at the pin on the ECU and I know it's pin C7.
You guys have any other input?
Old Nov 5, 2010 | 07:59 AM
speedooo's Avatar
My friend had the same exact issue when he did an MPFI swap on a dx...
Did you switch the two wires on the tps?
Old Nov 5, 2010 | 03:46 PM
I did my MPFI swap before the motor swap and no troubles with the TPS then, now I do. Wires have not changed or anything.
mustninty20
Oct 30, 2011 08:43 PM
rwcdrums
Oct 29, 2004 08:24 PM
G1 TEGGY
Jul 25, 2004 02:14 PM
bambam
Nov 12, 2003 06:45 AM
