high rpm
Old May 10, 2010 | 09:02 PM
joeli27's Avatar
Default high rpm
hey... i just got a b16a2 swap done last week into a 96 civic cx.. also i had a new o2 sensor (before cat) put int... the one after cat is old... and when the car is rolling in neutral the rpm is at 1500... when it's at a stop light the rpm is at 1300, after a few seconds it drops down to 800-900... has anyone had this problem? i am using a ractive tach gauge cause the cx never came with a tach... i extend the tach wire to the ecu's wire for the tachometer. is that the problem? forgot to mention.. it wasn't doing that when i first had my tach hooked up 2 days ago... it started doing that all of a sudden...
Old May 11, 2010 | 12:05 AM
Koopa Troopa's Avatar
Default Re: high rpm
Vacuum or maybe your throttle cable is too tight
Old May 11, 2010 | 01:53 AM
b20hatchek's Avatar
maby im just being a smarta$$ but maby you should have did what i did for my cx and just put in a ex gauge cluster so you have a factory tach
streetrider002
Aug 8, 2011 11:57 AM
SleepnCiViC
14
Jan 16, 2004 05:46 PM
94hondaLS
Jun 23, 2003 10:28 PM
hybridreams
Sep 25, 2002 07:46 PM
