ft/fs xbox360, turbo parts
ive got an xbox 360 with memory card, 20gb hd, 2 controllers, 4 games.
Also a semi turbo kit or part it out dont matter
all you would need is a wastegate, piping and oil lines.
t3/t4 turbo w/downpipe (took this one off because i thought it was bad because my car was smoking put a newer one on the car's still smoking, blown piston rings may or may not be good has some play but same as my other one, downpipe has a crack in it and a hole can probably be welded or used as a flange 3" dp its cut where it goes into a 90 degree)
Front mount intercooler flatblack (small dent on the bottom)
ramhorn turbo manifold (small hairline crack on weld behind the manifold)
type s style bov
fpr (not the one on the fuel rail
fmu
may throw an edelbrock b series fuel rail with new gauge if its worth it.
im looking mainly for a b series swap/ b18b1 longblock with lower mileage, 15" rims oem are fine, 94-97 integra lip let me know what you have/.
type s style bov
fmu
games are assassins creed 2, gta4, need for speed mw, and bioshock if i can find it. and idk make an offer lol i need $$$ to fix the car. did it run high 12's? he had a time slip in there showing 12.89
if he had a slips its gotta be correct... i didnt go there like i said i wuz just goin thru pix from the track... ill c wut kinda looot im workin with friday n give u a offer on the xbox
arlight cool, thanks im getting my exhaust in on friday or so, then back to frijoles on sunday to get the rest of the stuff welded and a dumptube put on.
japan4racing
Aug 25, 2008 07:17 PM
Scotty
Jun 16, 2001 11:27 AM
