91dpfi injectors not firing
So like it says just got the car all together and it wouldn't start and I narrowed it down to the injectors not firing. Car does start if I drop water cap of gas down the tb. But I can see the injectors not spraying and they are getting fuel. Is there a fuse I'm not seeing somewhere?
Thanks guys!!!!
Thanks guys!!!!
Is there a certain volts/amps the injector should be getting to fire? They are getting power. But I don't see them spraying so they may be bad. But I do t know proper power.
