For anyone and everyone with a speedo problem...
Old May 10, 2010 | 10:25 AM
mikej94civex's Avatar
Default For anyone and everyone with a speedo problem...
i have had a non functioning speedo for over a yr! it would jump around, stay at 0 mph, get stuck randomly...i tried
replacing vss (vehicle speed sensor) and all the grounds, wires, plugs ect.. and nothin! soo instead of having to buy
another cluster i took apart an old cluster i had laying around. on the back of the cluster there r 3 philips head screws
holding the actual speedometer in the cluster. remove them and the entire speedo assembly will fall out. replace ur broken
one with one that u kno works and there u go! it fixed my problem after everything else searching would tell u didnt!
Old May 25, 2010 | 05:09 PM
timmy0tool's Avatar
Default Re: For anyone and everyone with a speedo problem...
werd! this is same thing as swapping the cluster. i've tried everything as well so the only thing left to do is this. kudos man!
blinger
11
Mar 26, 2024 08:08 PM
JDMJUNKIEMONKIE
11
Feb 2, 2010 09:41 PM
EJ8-Yao
Engine Management and Tuning
Apr 21, 2009 05:28 PM
jerry_ort007
Feb 17, 2009 07:00 AM
whitehf
May 10, 2007 08:41 PM
