Need Car Mech Help!!!
Old May 10, 2010 | 07:35 AM
401RIguy's Avatar
Default Need Car Mech Help!!!
i have a 1989 Honda Accord LXI.
the problem is that it wont go in gear when its started up. but then its not started up itll go in gear with no problems.
out of the blue it just did this one day. what can it be?????
i try putting it in 1st and starting it up and the car will just jump jump jump like its trying to start.
please help me out if anything.
Old May 10, 2010 | 07:48 AM
dravesef's Avatar
Default Re: Need Car Mech Help!!!
pressure plate, clutch or throw ut bearing.
Old May 10, 2010 | 08:05 AM
donvito#1's Avatar
clutch slave cylinder how does ur cluth pedal feel
Old May 10, 2010 | 08:06 AM
401RIguy's Avatar
My Clutch feels Fine. stepping on it feels normal
Old May 10, 2010 | 08:07 AM
401RIguy's Avatar
would the master cylinder be the cause of this?
Old May 10, 2010 | 08:23 AM
hondaon18's's Avatar
I say slave cylinder cause that was what mine did to me when I turned it on I could not get it to gear but when I turne it off I could so check your clutch slave cylinder it's probably that
Old May 10, 2010 | 08:27 AM
401RIguy's Avatar
out of the blues it just did that one day..
Old May 10, 2010 | 08:45 AM
dravesef's Avatar
a seal could have went bad in side a cuase it not to function correctly. u might need a friends help, but one guy presses the petal the other guy watchs to see if it moves, not just a little movement, make sure it extends all the way.
Old May 12, 2010 | 06:58 AM
401RIguy's Avatar
where is it located at? the slave cylinder?
from the looks of it, it extends out all the way
Old May 12, 2010 | 07:50 AM
senpai's Avatar
i concur
Old May 12, 2010 | 08:14 AM
Rtboy10's Avatar
http://www.wonderbart.com/images/08/...er_removal.jpg
Old May 12, 2010 | 08:18 AM
401RIguy's Avatar
i dont have one.
Old May 12, 2010 | 08:26 AM
Rtboy10's Avatar
ok then you have a cable transmission, try adjusting the cable (by turning the nut either which way) to see maybe if something is messed up with the cable. If not that then like others said pressure plate clutch throwout.
Rtboy10's Avatar
lol my bad I should have looked at the car make ect
Old May 12, 2010 | 10:24 AM
obeyphysics's Avatar
my car did the same thing and it was the clutch cable. it came loose from the slave, all it needed was to be tightened down again and it was fine. although i don't know if you're in the same boat as i was, how old is your clutch cable?
Old May 12, 2010 | 04:21 PM
JDM_YANG's Avatar
its time for a new clutch..this happend to me b4 and it was my clutch...
Old May 12, 2010 | 04:31 PM
JDM_Frijoles's Avatar
Icon5 Re: Need Car Mech Help!!!
This...
/Thread
madeinchina
Transmission & Drivetrain
May 16, 2011 12:38 PM
pkdog167
Sep 19, 2008 04:24 PM
Liquidgsr
Mar 8, 2007 03:18 PM
lo0nY
Feb 26, 2006 03:58 PM
johnqt3
Oct 7, 2005 11:05 AM
