Is this a real Revhard Turbo Manifold?
Old May 9, 2010 | 08:26 PM
denracho's Avatar
Default Is this a real Revhard Turbo Manifold?
I just found this online and it's selling for a good price. i just want to know if this is a real revhard manifold and looks like the 4th runner has been welded but it doesnt look that bad.also if a garrett t3/t04e turbo will fit on my b18b1 block w/ a/c.. need advice please..yay or nay??
Old May 9, 2010 | 08:33 PM
TheShodan's Avatar
Moderator
Default Re: Is this a real Revhard Turbo Manifold?
looks like a repaired revhard. yes. it is T3 flanged made for a t3/T04E with a 5 bolt turbine housing.
Old May 9, 2010 | 08:42 PM
denracho's Avatar
is it a good or bad buy..
Old May 9, 2010 | 10:56 PM
Mr.Spec's Avatar
bad buy .. cast .. cracked already is a pain
Old May 9, 2010 | 11:24 PM
denracho's Avatar
ok ty.. if im getting a blox log mani can i still use a t3/t04e turbo? hows the clearance on my ls block? thanks
Old May 10, 2010 | 08:00 AM
E85B18's Avatar
Its hard to weld on cast. My revhard cracked, I had it welded and the crack came back over time. Just buy a new one
Old May 10, 2010 | 02:58 PM
srmofo's Avatar
I also had a revhard crack in the same spot. I drilled the ends of the crack, heated it, welded it. Never had a problem again
Old May 11, 2010 | 01:04 PM
CX-R Hatch's Avatar
A2WXCXE3WQ34fdfdfdsdsghq
Mike_ef
Nov 23, 2013 10:24 PM
carlosd68
Jul 28, 2012 09:29 AM
kenbdSi
Sep 12, 2006 04:50 PM
00BoostedGSR
Jun 11, 2006 03:32 PM
99teggsr
Jul 26, 2003 08:41 PM
