Project B18c DA integra part out (twin cities area)
Old May 9, 2010 | 07:20 PM
quick gixxer's Avatar
Default Project B18c DA integra part out (twin cities area)
Well...... For right now I'm getting out of the tuner scene. Getting married soon and Want the garage space back for bigger and better things.
B18c shortblock after a trip to the machine shop for a full rebuild.block has been bored/honed/hot tanked/some parts bead blasted ect... All of the rotating parts have been balanced. I got the block bored .5mm over so it is now sitting at 81.5mm which yields a slightly higher displacement (1819.82cc compared to 1797.56cc) It has new pistons and the rod have been shot peened. The PR3 (B16a) 81.5mm pistons in a GSR motor will bump the compression to around 11.5:1 using and OEM 3 layer .030 head gasket but if you choose to run a 4 layer .040 head gasket (which is for sale in this thread) you will get around 11.1:1. Block is pretty bare and has a fresh coat of engine enamel on it.I have over $1000 into the block alone
$800
The block back from the machine shop
The block after a little spray (not done yet, and oil pan needs some black)
The new pistons:
Ported and polished (By HeadWerks in Bloomington, Mn) GSR head with new valves and new Type R valve springs. OBD1 distributor, GSR intake manifold, Throttle body, Hondata Heat shield gasket. Head looks great. Needs cam gears and a few small things and should be ready to go. $850 OBO (great deal)
Exedy stage 1 clutch for 91 Integra. They go for $275 on ebay all day long. $250
Clutch:
7.5 Lb Fidanza flywheel $140 (will fit maybe b-series motors i think)
Flywheel:
Custom Cometic 81.5 .040 MLS head gasket for GSR $85
Oem Honda Type R water pump and GSR timing belt $100 (great deal)
Da integra Prothane shifter bushings $15
Da integra Energy Suspension motor mount inserts $30
ARP head studs for GSR $125
I bought a full cat-back HKS HiPower exhaust used from a guy on another forum, it's a little dirty but in good shape. This is one of the most sought after exhausts for a DA and getting harder to find nowadays.
I think $250 is a great deal.
HKS HiPower (needs a cleaning)
Don't really want to ship and I prefer to work local, but something might be able to be worked out. Thanks for looking
eg6madness
Dec 20, 2012 05:36 PM
Boostedvti
Oct 21, 2010 02:32 PM
aznej2
Oct 22, 2005 02:53 PM
SEFIxCivic
Oct 9, 2003 06:52 PM
pinota
Jun 20, 2002 01:32 PM
