1.9 gsr NA build whp??
Run a search on Pro2 cams. That will list up all the people that have used Pro2's and if your lucky what they made. Come on, seriously you have GSR with raised compression and Pro2 cams. There are a bunch of these out there. Nothing special, move along.
You may want to look here first.
Official All Motor Dyno Thread! https://honda-tech.com/forums/all-motor-naturally-aspirated-44/official-all-motor-dyno-thread-1583606/
Official All Motor Dyno Thread! https://honda-tech.com/forums/showthread.php?t=1583606
I'm not asking about my build, you were asking about your's, and you said you couldn't find anything similar to it. Must be very special.
I wasn't trying to be a dick all it takes is a bit of time to search around, H-T.
By the way what is fuel system plan? Stock 240cc's won't get it done, you'll need 310's or 370's.
Since you brought up my sig, lets just hope your Pro2's can out do my ITR cams in my 1.8ltr GSR.
In the Official All Motor Dyno Thread! on the last page there is one with Pro2 cams, it made 216. This has a larger displacement than yours, so I would think yours would make less than that.
honestly man this is the first build i have done, i knwo it doenst compare to most of the builds on here, so im not trying to be a idiot either and im new to honda tech and i dont know how to work this site that good, and i didnt mean mine is special i just wanted to see if anyone had any idea what kinda power it would make. ive asked a few ppl and i have had answer from 170-190whp.
Back when I was a newb I use to study up on about 10 or so posts a night to gain a general understanding of different things on Hondas and Acuras. That was over 10 years ago and even to this day I learn something new every day. Right now I’m looking into IM’s for an 86x89 12.5:1 build.
Realistic numbers for your build would be from about 190-210 on a dyno jet. Post back up how it does.
Also other examples would found here ”Let's see your 1.8L OEM Bottom-end, ALLMOTOR, 91 Octane Dynos” https://honda-tech.com/forums/all-motor-naturally-aspirated-44/lets-see-your-1-8l-oem-bottom-end-allmotor-91-octane-dynos-1263436/ These are closer in displacement to your set-up.
And I'm not done yet.
GSR Intake System Upgrade https://honda-tech.com/forums/all-motor-naturally-aspirated-44/gsr-intake-system-upgrade-2671606/
Going back to the dyno this week. I hope my replacement fuel line hose shows up.
GSR Intake System Upgrade https://honda-tech.com/forums/showthread.php?t=2671606
either, but with 440s, you can use em if you ever want to do more.
And Im a first time builder too with a setup almost exact to yours, except im using jun3 camshafts instead. With ENDLESS hours of google and honda-tech searches, im finally almost done with my motor. With your setup, anything around 200whp is realistic, and should be more than enough to get you around nicely
GL on your build bro
