Mushy clutch
Old May 9, 2010 | 11:46 AM
chb93's Avatar
Default Mushy clutch
About 6 months ago I was driving and my clutch went mushy and stuck to the floor. After I replaced the slave cylinder it was ok. The other night when I got out of class my clutch began to feel weird again. It was fine on the way there but when I came out three hours later it was feeling really soft and catching really low. I haven't driven it since. I think that I have air in the system somewhere and would like to know how to bleed the slave cylinder. The engines a b17 with a ys1 tranny in an eg if that matters. Thanks alot
Old May 9, 2010 | 12:03 PM
98civdx's Avatar
Master Detailer
Default Re: Mushy clutch
On the end of the slave clynder there is a bleeder screw, pump the clutch 10-15 times and open up the screw, then close tightly and repeat untill clutch feels good.
You may have a leak in your master cylinder, is there any wet spots on the fire wall, behind dash?
Old May 9, 2010 | 08:11 PM
chb93's Avatar
sorry I didnt reply quicker I was at work. Im going to try that tm thanks. No there were'nt any wet spots and I replaced my master cylinder when I replaced my slave cylinder so I dont think its that. Hopefully bleeding it is all I need to do. Also, what kind of fluid do I use just regular brake fluid is fine right? Thanks for the info
Old May 9, 2010 | 08:15 PM
98civdx's Avatar
Master Detailer
yes regaular break fuild will work.
Old May 9, 2010 | 08:20 PM
chb93's Avatar
great. Thanks again
gooblinn258
Jan 18, 2014 05:02 PM
RDAYA0
Dec 14, 2006 05:31 PM
FuNkDrSpOt
Oct 10, 2006 09:48 PM
vteg
Aug 1, 2002 03:10 PM
