What do you tech's think abou this N/A set up
Old Sep 11, 2002 | 05:38 PM
DocV's Avatar
Default What do you tech's think abou this N/A set up
Ok here's what I have: 2k1 GS-R I/H/E and test pipe this is what i want to do in the spring. JUN II's or III's/ All JUN valvetrain/ ITR intake valves/ JDM Pistons 11.1:1 cr pistons. This is basicially what I want for now. Give me your opinions or techinical advice about my set up thanks
Hova
Old Sep 11, 2002 | 05:42 PM
Malice's Avatar
New User
Default Re: What do you tech's think abou this N/A set up (VtecNit2k1)
sounds like a good setup. if ur gonna do JUN then go with the 3's. and be sure to get a header that can breathe, like a jdm itr or Toda
Old Sep 11, 2002 | 05:43 PM
DocV's Avatar
Default Re: What do you tech's think abou this N/A set up (MaliceGSR)
I have a greddy 4-2-1 then a test pipe then a greddy evo I was think about jdm 4-1 though
The Rob's Avatar
Get JUN3's with valvetrain, VAFC, and get CTR pistons. You'll be a beast then.
Old Sep 11, 2002 | 05:46 PM
DocV's Avatar
Default Re: What do you tech's think abou this N/A set up (Zero Effect)
Why would I go w/ CTR pistons they have a lower cr 10.8:1 while JDM ITR has 11.1:1. I figure w/ higher cr and right tune that would be a beast.
Old Sep 11, 2002 | 05:48 PM
Malice's Avatar
New User
compression with ctr's in a GSR motor will be over 12
Old Sep 11, 2002 | 05:49 PM
DocV's Avatar
oh, well i was just looking @ the CTR and they are high domed will they fit w/o modifications? It lookes like it might hit the valves.
Old Sep 11, 2002 | 05:51 PM
Malice's Avatar
New User
na you'll be alright. just run at least 91 octane and it'll be a beast
you can always clay the motor to be sure u wont hit anything, but like i said you 'll be fine
Old Sep 11, 2002 | 08:08 PM
spoonek4's Avatar
Umm...JUN 3...any plan on intake manifold and ECU setup?
This link mite help on getting compression ratio:
http://www.c-speedracing.com/howto/c.../compcalc.html
Old Sep 11, 2002 | 08:28 PM
Allstar's Avatar
New User
Default Re: What do you tech's think abou this N/A set up (spoonek4)
I say get the ctr's or look into some forged pistons. With the jun 3's and high compression you are going to need some good tuning and a couple hours on a dyno. Very solid set up, should make good power.
Old Sep 11, 2002 | 08:38 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Hova
Sounds like a good start. Personally I would get the JunIII cams and valvetrain, a ported head (imho very important to get the most out of the cams), Skunk2 mani, a good header (jdm or hytech) and at least a 12:1 cr (to get the most out of the cams). Your stock ECU wont cut it either (it turned my bumper black ) so either get the JUN ecu or get a standalone. Then you will have a NA beast (200+whp).
Old Sep 12, 2002 | 04:52 AM
DocV's Avatar
Default Re: What do you tech's think abou this N/A set up (FrostyDC4)
For ECU i was thinking about Hondadata I heard they are really good. This car is still a daily driver and I just wanted a little more beastly power. How would higher cr like 12:1 work w/ my daily driving?
Old Sep 12, 2002 | 05:00 AM
fiebru1119's Avatar
some good tuning and 93 octane you should be fine
Old Sep 12, 2002 | 08:14 AM
Rob Dizzle's Avatar
Default Re: What do you tech's think abou this N/A set up (fiebru1119)
i would rather spend less on cams, and more on better intake (comptech) better intake manifold (ported skunk2/itr manifold) and better exhaust manifold (smsp, hytech, JG tweaked by IB)
that way you might spend a lil more money, and get same or better power, but you arent stressing out your engine as much. going to 9 to 9.5k is not a very good thing.
dont forget you will need to get crank re-polished, hondata intake manifold, and bigger injectors
Old Sep 12, 2002 | 09:46 AM
LOwrestling2001's Avatar
Default Re: What do you tech's think abou this N/A set up (bob46802)
i say screw all motor *****!! go FI hehehe...just joking haha...i used to be NA, and the darkside stole myass....but yea that'd be a tight setup just run like high octane (i think it's safe on 93 octane with 12+ comp). hehe
Old Sep 12, 2002 | 11:37 AM
Leimokei's Avatar
New User
Default Re: What do you tech's think abou this N/A set up (LOwrestling2001)
good setup in my opinion...JUN III, retainers, springs, Skunk2 Intake Manifold or Type R Intake Manifold (requires modification)..get your head ported and polish...more, bore your throttle body to about a 68mm..get some cam gears..run compression rate at about 12:5:1...and get fuel pressure regulator and a hondata stage 2..and with a header a recommended getting either hytech or SMSP...either one will work well..and run 2.5 inch all the way back...run 91 octane or you might need to run race fuel mixed with 91 octane...
Old Sep 12, 2002 | 11:51 AM
Spyderwebab's Avatar
Anyone out there running the CTR pistons on Stock GSR Rods?...how long have they held out and have you heard of anyone throwing a rod as a result of such high compression on stock rods...
I'm asking because my engine was blown in a Hydrolock and I'm in the process of building my new motor...so I was thinking about Doing the JDM ITR pistons to get the 11.5:1 CR, but if the GSR rods can hold out on 12.1-12.5:1 CR than hell I'm sure the Toda B's would love that even more.
(also worried about Detenation, We've got a great supply of 93 octane out here, anything else I need to worry about besides tuning to prevent it?)
Old Sep 12, 2002 | 12:32 PM
wuhungsixxx's Avatar
New User
Default Re: What do you tech's think abou this N/A set up (Spyderwebab)
i would also like to know if the gsr rods would work with CTR pistons...but i can only get 91octane in my area...and i was wondering if higher compression would cause me to fail emissions...in know the junIIIs will but i plan on running skunk2 stage 1s which should pass tailpipe but what if they were teamed with CTR OS
Old Sep 12, 2002 | 04:35 PM
DocV's Avatar
Default Re: What do you tech's think abou this N/A set up (wuhungsixxx)
Ahhh **** Vinh you blew your ****? sucks for ya lol
Old Sep 15, 2002 | 11:40 AM
TimoneX's Avatar
New User
I'd personally stick with the JDM ITR pistons. 11.34:1 with GS-R head. This is the setup I'm building(got pistons yesterday). I'm thinking of having the rods shot peened, but I suspect they'd be fine w/o it. I may go for some flat faced valves later, which would give me another .2 or so, not sure. Another option would be a thinner head gasket...my point is that with those pistons you can get to slightly over 12:1 with tricks, whereas with the CTR pistons and wild cams you could have clearance, detonation, or rod failure issues from the get go. Naturally properly tuned you could get by, but don't get trapped anywhere w/o 92+ octane gasoline.
jdmB18CT-R
Feb 10, 2006 10:41 PM
Blazin Si
21
Jan 14, 2004 10:47 AM
hybridEj6
14
Oct 2, 2003 06:18 PM
StinkyTofu
Mar 3, 2002 08:53 AM
Big Teggie
Jan 25, 2002 12:48 AM
