tranny grinds
Old May 8, 2010 | 07:52 AM
turbosivtec's Avatar
Default tranny grinds
put new headgasket in..starts fine..when changin to 3rd gear.. tranny started grinddin..but all gears works but grinds..and when pressin on clutch it stops..help!!any idea of the problem?
Old May 8, 2010 | 10:40 AM
mouab18c1's Avatar
Default Re: tranny grinds
It sounds to me like your trying to shift without stepping on the clutch? Or you're im confused
Old May 8, 2010 | 11:36 AM
well the thing is, when I turn on the car it grinds, even on neutral, but when I press on the clutch pedal it stop grinding...but the thing is I didnt even mess with the transmission at all. All i did was replace the head gasket...so Im just kinda lost to where to find the problem...any help would be appreciated...thanks
Old May 8, 2010 | 11:48 AM
mouab18c1's Avatar
So it grinds when the car is idleing with the clutch pedal up? Hmm something probably came loose. Did you use anything to hold the crank pulley while taking off the crankpulley? It could have loosened up the flywheel bolts.
Old May 8, 2010 | 01:39 PM
honda_luvr_2000's Avatar
Sounds like the input shaft bearing. It will make noise at a stop in neutral with the pedal up & go away when you press the pedal. If it's a gear grind, did you pull the trans out or drain the fluid or pull the axles out or anything? If you pulled the trans, did you lose one or both dowel pins? Check the fluid level and make sure it's full if you think it's a gear grinding. If you don't use the dowel pins the trans will NOT line up how it's supposed to with the clutch & flywheel, you WILL get all sorts of noises/problems including complete transmission failure &/or engine failure. If it's more of a chattering noise then it's probably the input shaft bearing.
Since you say you didn't mess with trans at all, then I'd be willing to bet it's just unlucky that it decided to start making noise at this time. Still I'd double check the fluid level just to make sure you aren't low.
mfisher1987
Transmission & Drivetrain
Feb 8, 2015 05:58 PM
jrhcivak
17
Apr 11, 2012 03:55 PM
supereg2
Mar 21, 2008 09:51 AM
Agito
Aug 26, 2006 12:09 PM
J-Brooks
Dec 17, 2002 10:23 AM
