92-95 Civic Vtec Wiring Trouble
Old May 6, 2010 | 08:51 PM
MN95EJ1's Avatar
Default 92-95 Civic Vtec Wiring Trouble
I put a JDM GSR into my 95 Civic dx and using a 92-95 civic ex harness. Can any one with this harness show me a pic to which plug is for the IACV and which is for the IAT sensor? I looked everywhere and find nothing helpful unless its a picture. I heard you can burn your ECU if you get the two mixed. Also got a question about the heater inlet and outlet hoses. Which one is the in and which is the out on the firewall? Thanks in advance!
Old May 6, 2010 | 09:02 PM
1992hondacivicvx's Avatar
Default Re: 92-95 Civic Vtec Wiring Trouble
your iacv is on the back of the intake manifold the one that has the water hoses the plug a a round one with green and black wires on them and the other plug should go on the manifold right next to the fuel rail hope this helps
Old May 6, 2010 | 09:47 PM
MN95EJ1's Avatar
you got to be more specific, there are two plugs that fit both the iacv and the iat sensors. You're just explaining about the water temp plug. I need to know exactly the colors to the iacv and the iat plugs for the ex harness.
Old May 7, 2010 | 03:42 PM
CivicSpoon's Avatar
The Blu/Yel & Yel/Blk plug is the IACV, and the Red/Yel & Grn/Wht plug is the IAT.
For the heater hoses, looking at the firewall, the left one is the Inlet and the right one is the Outlet.
Old May 8, 2010 | 12:35 PM
EGgoJDM's Avatar
Check this web site. I think you find what you looking for
http://www.ff-squad.com/technet/
Old May 11, 2010 | 03:11 PM
if i said that the iacv has two wires black and green and theres only two spots where u can connect them and i already said where the black and green go i am sure u know where the other plug goes to--- hint its by the fuel rail
Old May 11, 2010 | 03:50 PM
HondaPartsHero's Avatar
Technical Hero
Old May 11, 2010 | 03:53 PM
Technical Hero
Bjm1118
Mar 17, 2019 11:51 AM
carlos8
Feb 24, 2017 11:28 AM
Shay Cothran
14
Oct 10, 2015 03:16 AM
ddong2lee
Jan 5, 2004 02:46 PM
civictyper85
Mar 8, 2003 12:30 PM
