jdm type r. Alternator + harness problem ~HELP~
Old May 6, 2010 | 07:02 PM
h22paul's Avatar
Default jdm type r. Alternator + harness problem ~HELP~
ok so heres my issue. Doing a jdm type r swap into my 99 Integra
I baught a 99spec (Stamped) JDM B18C Type R. It came with a 4 Prong alternator plug.
But im using a 1999 Integra LS engine harness. Which has a oval 3 Prong alternator plug in.
I will be using the JDM Type r ECU.
So heres what im thinking. Since i am using the jdm ecu, it will be reading 4 wires. If i buy a 3 pin alternator to fit my 99 LS harness, it wouldnt run properly.
Has anyone ever ran into this problem or know a solution to this?
Also thinking of cutting and wireing the 4 prong plug from the jdm harness i have and putting it on my 99 LS harness than running the last wire to the ecu. But do all 4 wires go to the ecu and what pins would they be?
Also what does each wire do that would help me.
94IntegraLs04
Aug 10, 2005 09:13 PM
rice4life
17
Mar 16, 2004 03:33 PM
rice4life
Mar 9, 2004 03:46 AM
absolut b18
Jun 22, 2003 11:10 PM
