keeping the crank from moving on an auto b18a1
Old May 6, 2010 | 05:44 PM
Shaguar47's Avatar
Default keeping the crank from moving on an auto b18a1
hey guys, Im currently in the process right now to change my friends timing belt and Im at the crank bolt and I've tried everything to get the crank from moving. We've applied the brakes, put the car in neutral, drive, reverse, park and nothing. Its already after 10 and the local advanced auto parts store is closed so i can't get a crank holder and i was hoping to do this without using one. so is there any method we can do to keep the crank from moving? it's a 93 integra b18a1? Hope someone can help me out here. Thanks
Old May 6, 2010 | 06:49 PM
nsxter's Avatar
Default Re: keeping the crank from moving on an auto b18a1
remove the starter jam a big *** screwdriver in the hole to keep the torque converter and flex-plate from moving i dont recommend this but i have done it before
Old May 6, 2010 | 07:29 PM
dntnedvtec's Avatar
Wait till tomorrow morning, and go buy a crank holder. Your gonna need it when you assemble whatever your doing anyways....
Old May 6, 2010 | 11:01 PM
AcuraLsSE's Avatar
I haven't done this on an automatic before but IF you wanted to do it tonight I would put it in 2nd, have someone stand on the brakes as hard as they can, and try to remove it after applying some penetrating oil.
Otherwise wait till morning...
Old May 8, 2010 | 11:46 AM
Shaguar47's Avatar
We decided to stuff the screwdriver in between the flywheel and it worked great! Thanks everyone for the advice. Much appreciated!
Old May 8, 2010 | 07:32 PM
97lsteggy's Avatar
For the future I would invest in a honda crank pulley removal tool. Best $35 I ever spent.
Old May 9, 2010 | 04:57 AM
Shaguar47's Avatar
Just found one on Amazon for like $25 bucks and just ordered!
BigD4207
Engine Machining & Assembly
Mar 28, 2018 09:56 PM
wsudu
Nov 10, 2016 03:00 PM
Tims Toy 500
69
Mar 17, 2011 06:11 AM
TB123
Jun 8, 2010 03:08 PM
pegasus01
Jun 20, 2009 09:25 PM
