Throttle body size
Old May 6, 2010 | 03:09 PM
93WhiteHatch's Avatar
Default Throttle body size
Ive been searching and every where i get different answers im wonder since i cant get one of each and measure them myself what are the bore size for a B16b(ctr), b16a2(si), b18c(gsr) and the b18c5(itr)
Old May 6, 2010 | 03:12 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Throttle body size
http://www.maxbore.com/
they have a bit of info on sizes.
Old May 6, 2010 | 03:19 PM
Deetz's Avatar
Crazy Honda Guy
B16b(ctr) 62mm
b16a2(si) 60mm
b18c(gsr) 60mm
b18c5(itr) 62mm
For the money it costs to buy a larger TB, you can get an aftermarket one in 65, 68 and 70mm sizes for like $130
Old May 6, 2010 | 03:33 PM
68mm Blox TBs are only $100 shipped in the marketplace. I have one and have no complaints.
Old May 6, 2010 | 03:38 PM
b20hatchek's Avatar
having a oversized tb wont help much with having oem manifold, to make the most power from your intake you need to match the inlet on the mani and the tb
Old May 6, 2010 | 03:40 PM
this is gospel. Many people (somehow) overlook this. Even aftermarket(S2, Blox, Edlebrock, etc) manifolds all need to be portmatched at the TB.
Old May 6, 2010 | 03:45 PM
b20hatchek's Avatar
yup ^ to get the most you gotta keep going, no stoping for "thats good enough"
Old May 6, 2010 | 10:41 PM
-__-'s Avatar
^^werd.
you could have the biggest throttle body ever. without being portmatched, its fkn useless lol. kinda like having a full exhaust setup with bigger piping and then at the end, it goes to like a 1 inch muffler hahaha.
Old May 8, 2010 | 10:43 AM
Originally Posted by Deetz
B16b(ctr) 62mm
b16a2(si) 60mm
b18c(gsr) 60mm
b18c5(itr) 62mm
im wondering if these sizes you say are where it connect to actual intake or the outlet where it connects to the intake manifold???
Old May 8, 2010 | 10:47 AM
streetsold6teeny8's Avatar
These sizes you guys post are they on the manifold side of the throttle body or on the intake side of it...
I was told from a guy selling me a Integra type R one that 64 is the intake side and
62mm is the side that mates to the manifold.. is this correct????
Old May 8, 2010 | 11:22 AM
$kreech's Avatar
i have an ek9, b16b, stock type r TB and IM... can i upgrade from the stock 62mm TB to say a 65mm without having to change the IM? the type r IM's are suppose to be a bit bigger that the Gsr or Si IMs.
Old May 8, 2010 | 11:34 AM
Yes the ITR/CTR are bigger than the regular b16/gsr but yet to get the most out of a bigger throttle body you would have to port match it with the IM, but i do suppose you could just bolt it up
Old May 8, 2010 | 01:02 PM
some one answer my question plzz
Old May 9, 2010 | 08:04 AM
$kreech's Avatar
its supposed to be the size right through. i checked my ctr TB and its the same size right through, doesnt get bigger or smaller at either end.
Old May 9, 2010 | 08:10 AM
EJeff8's Avatar
I just put a thread up in this. I was going to do a matching BBk TB/IM install but was told it will really do me jackshit.
Old May 9, 2010 | 08:19 AM
forcefedferio's Avatar
IIRC that is because you are putting it on an otherwise stock D-series
Old May 9, 2010 | 08:33 AM
EJeff8's Avatar
Ah, indeed.
Old Jan 19, 2011 | 06:22 AM
ekzoom210's Avatar
Will I have problems with my 70MM Throttle Bodys fitting my Skunk2 intake manifold without any mods or do i need to mod it so the intake manifold will be the same size as the throttle body?
Mando
Old Jan 19, 2011 | 06:47 AM
grumblemarc's Avatar
The Grumpiest
You knew the answer to this question before you even asked. Port match.
Old Jan 19, 2011 | 09:49 AM
Red_Army's Avatar
yes they will fit. will it work well? no. you could have gathered that info IN this post.
as grumble said and like 5 others port match first.
Old Mar 1, 2022 | 09:16 AM
Ek4_Daniel's Avatar
B16b(ctr) 62mm
b16a2(si) 60mm
b18c(gsr) 60mm
b18c5(itr) 62mm
Yo can you actually confirm if a 62mm throttle body will fit on a b16a 60mm intake manifold? And even if not noticable, would it make minimal difference? I have both on shelf and would wonder which to install on my b16a2 with b18c5 itr head & b16a intake manifold
Old Mar 3, 2022 | 07:26 PM
wunfstgsr's Avatar
Loved
Community Favorite
Try posting your own thread mate!, this thread is older than Clint Eastwood
For the record putting a 62mm TB on a 60mm manifold will actually make you loose performance/HP. The 2mm step will cause issues if not port matched!
HondaCivicSE
13
Dec 14, 2013 09:43 AM
SiR Koopa
Oct 5, 2007 07:54 PM
1hotcivicSi
Apr 7, 2004 08:41 AM
jaycuzz1
Jan 19, 2004 08:30 PM
