Quick question...What color does transmission fluid burn?
Old May 6, 2010 | 01:22 PM
BoldFart16's Avatar
Default Quick question...What color does transmission fluid burn?
Trying to figure out a smoking problem *that doesn't come from exhaust.
Old May 6, 2010 | 01:25 PM
dth0ng69's Avatar
Default Re: Quick question...What color does transmission fluid burn?
lol transmission fluid doesn't burn, it doesn't go to the motor. The only way it would burn is if its leaking and it goes to the exhaust.
Old May 6, 2010 | 01:28 PM
BoldFart16's Avatar
What are you smoking? Of course it burns...
Here's how we find out. Drive your car for an hour. Pop the hood, touch your transmission. If your hand burns, the transmission fluid will burn.
Old May 6, 2010 | 01:29 PM
BoldFart16's Avatar
Oh should clarify, not through tailpipe.
Old May 6, 2010 | 01:43 PM
waaBAAH's Avatar
dont let these guys fool you...transmission fluid can burn BUT not like the way i think you mean. burnt tranny fluid will smell burnt and should be a darker color. the fluid can be burnt be a couple of diffrent things like towing, overloading etc.. all things your probably NOt doing.
if you see smoking and it is not coming from the tailpipe i would inspect your exhaust system. check for residue of oil/coolant etc on the exhaust manifold
Old May 6, 2010 | 02:08 PM
Gunmetal_B20_Hatch's Avatar
white or light grey
Old May 6, 2010 | 07:32 PM
raidacaipo's Avatar
x2.. it could be oil dripping from your fuel filter. This will definitely hit the top of the head downpipe which will evaporate due to the heat of the header causing it to smoke or smell
gen2ty
Mar 24, 2015 09:19 AM
david1227
10
May 21, 2013 02:51 PM
Bad_dude
May 27, 2008 11:16 AM
..::91TEG-G2::..
Nov 15, 2004 05:35 PM
Flux
Mar 26, 2002 04:18 PM
