leaking some kind of fluid?
I own a 1993 civic and i was doing body work on it just half an hour ago. I come to find that the towels/cardboard/etc that was in front of it were SOAKING wet. My car is slammed so i can not get under it without going through the trouble of lifting it up with my 5$ jack. I got on the side of the car and looked underneath. the fluid seems to be leaking from the exhaust?? It doesnt smell like gas/anti-freeze or anything. the fluid smells like water? What could it be??
Man U FTW
Re: leaking some kind of fluid?
What color is it? I can't think of any fluids (other than water) that dont smell...coolant is sweet, powersteering fluid is slimy and stinks, oil is obvious, etc...
to get my car up I put it on jack stands that are on cinder blocks that I filled in the holes with concrete use 2 side by side to have a wide base for the stands to be on works pretty good but to get it up the last bit u gotta put the jack on some blocks too
Posted from Honda-tech.com App for Android
The Grumpiest
If you cannot get under the car slide a piece of white posterboard under the engine and let it sit overnight. Pull it out and see what colors you have on it.
Turned into a "how to jack your car up" post lmao. If it's not red or oily, counld be a leak travelling down the exhaust after you jack it up. Gravity sux. Check the water pump. Check for a drippage on a level surface. Of course look under the car before you jack it up to see any possible leaks. Sounds like it's a leak somewhere just travelling. It's impossible for a exhaust to leak any kind of fluid unless it travels in my opinion.
jmai86
07-06-2012 03:39 PM
Bad_dude
05-27-2008 11:16 AM
