gsr swap need help!
okay this is my first post on here im completely stuck and fed up with this swap. i have a 1990 dx civic hatchback that im putting a gsr in, i have hasport mounts, DA t bracket, and DA mount that is bolted onto the side of the block. everything is ready i have the wiring harness plugged into the motor and the car the motor is in the bay with the rear mount and tranny mount inplace but the drivers side mount wont line up nomatter what i do its always about 10degrees off! is there a differnt block mount from a da i could get? or what i dont understand ! if i cant find a solution im just going to reweld the mount in the engine bay to accomidate for the 10degrees. just wanted to see if there was anyone who can actually help before i cut the mounting bracket and move it.
the soL that could
Welding / Fabrication
Aug 21, 2011 09:12 PM
fastcrx420
Oct 25, 2009 04:48 AM
