Stock H22 intake manifold idea
so I was sitting here playing with my stock IM cause i just installed a skunk2 on my motor with has nothing other then hytech reps, ecu and velocity stack and 2.5inch all the way out exhaust, based on feel high end its great, but i lost alot of low end torque and throttle response its not great, now im sitting here looking at the stock manifold and I know alot of ppl remove the butterfly valves from the plate, but has anyone ever tried just removing the plate completely? mean you would decrease the air volume in the chamber, but then the manifold looks more towards the likes of the euro r, I know, i said "looks",
im actually goin to try this as I have a h22 in a 3rdgen so my manifold is easy to remove. I know nothing about intake manifolds so I thought putting this out there to see what you guys think
Haha, too true. Am I incorrect in assuming that both will generally lose low-end torque but make gains in the upper rpm range compared to stock?
teeheehee, nice to see you around here
It will have gains across the entire RPM range if you tune it. Not sure about running on the stock ECU
shocker911
14
Feb 23, 2014 09:00 PM
