Missing Engine ground
Old May 6, 2010 | 02:05 AM
BlackShingo's Avatar
Default Missing Engine ground
Ok, I am trying to diagnose why my cooling fan won't work and I want to see if this is the case before I go through all the trouble of trying to test relays and such. There is a engine ground wire that is suppose to go from the front driver's side of the valve cover gasket to the front Radiator Support. Would that missing ground wire cause the fan not to work? The missing ground if you all wish to know is Engine Ground A T3-G2, according to the service manual.
Old May 6, 2010 | 03:37 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: Missing Engine ground
That one doesn't do much.
Make sure the thermostat ground has a good connection and that the temp sensor next to it is working.
Old May 6, 2010 | 06:36 AM
Gotcha. Will do. Is there a way to test the Thermoswitch?
Old May 6, 2010 | 06:42 AM
Former User's Avatar
Unplug the switch on the thermostat housing and then install a jumper wire across the 2P wire harness connector. The fan should now run whenever the key is in ON(II). If so, the switch itself is probably bad.
Old May 6, 2010 | 07:00 AM
Never mind. I got what you meant. Thanks bro!
Old May 6, 2010 | 07:39 AM
Originally Posted by BlackShingo
2P Wire harness connector?
The plug on the wire harness side.
KINGVEM^^ED6
19
Feb 20, 2012 04:14 PM
quikrpm'z
Jul 27, 2005 12:01 PM
scrubachu
Aug 28, 2004 11:38 AM
scrubachu
Aug 28, 2004 07:21 AM
