Honda wiring questions.
Old May 5, 2010 | 10:47 PM
coupatroopa's Avatar
Default Honda wiring questions.
I just purchased a 1996 Honda Civic CX Hatchback. The car has a mini-me swap with d15b7 bottom, d16z6 head, and a p28 ecu. There is no jumper harness as the seller never finished the project. Would I just need to buy the ecu adapter harness from rywire/chasebays and be good to go? The car will be equipped with a B20vtec later in the year.
Old May 6, 2010 | 06:58 AM
Default Re: Honda wiring questions.
To the top.
Old May 6, 2010 | 08:20 AM
Red_Army's Avatar
wouldn't even bother to waste the money unless your keeping that engine for something.
Old May 10, 2010 | 03:22 AM
What is your reasoning for this?
Old May 10, 2010 | 07:01 AM
CivicSpoon's Avatar
Yes, you should just need an OBD2A to OBD1 conversion harness, to plug in the P28 ECU.
Old May 10, 2010 | 11:48 AM
Cool. I guess I will contact rywire and order one today.
Old May 11, 2010 | 07:59 AM
I just picked up the car and it does not have the harness that runs from the ecu to the engine harness. Does anyone know where I can locate one?
Old May 11, 2010 | 08:06 AM
jdmh22eg2's Avatar
well u can do kinda cheap
1. u can get any cx harness from junk yard and do it right(just the section u are missing)
2. u can find the correct ex harness plug and play to vtec harness
3. find any harness and try and make work but can be a bitch with all the other models with diff engine harness
Old May 11, 2010 | 08:17 AM
apexi_rsx's Avatar
the 40 dollar ebay conversion harnesses work perfectly fine and you could save 100 bux. wiring vtec is not that hard to do and many wire ups on this.
Old May 11, 2010 | 09:26 AM
Are you talking about the ecu conversion harness. Because I also need the harness that runs from ecu to engine harness.
Old May 11, 2010 | 02:09 PM
I am putting in a OBD1 motor in this car. Can I just use the d16z6 engine harness?
Old May 11, 2010 | 05:28 PM
CivicSpoon's Avatar
Exactly what harness are you missing? The 6th Gen Civics ('96-'00) use a 1-piece harness, that runs from the ECU straight to the engine. Where the '92-'95 Civics and OBD1 & OBD2 Integras all use the 2-piece harnesses (ECU to shock tower harness & the shock tower to the engine harness).
Old May 11, 2010 | 05:55 PM
I was thinking it was like the 92-95 civics. That is all I have had. So I can just use the one out of my 95 ex coupe? I have a parts shell sitting here that I can get the harness from.
Old May 11, 2010 | 06:37 PM
CivicSpoon's Avatar
Technically yes, but it's way more work than it's worth. You'd have to swap over the entire dash harness as well, meaning you'd have to rewire a lot of things; like the gauge cluster, clock, rear defroster, etc. So realistically, you'll need a '96-'98 Civic harness.
Old May 11, 2010 | 06:57 PM
For a obd1 motor?
Is there any good write ups on this?
Old May 11, 2010 | 08:41 PM
I have located a 98 y8 harness.
Old May 18, 2010 | 02:22 PM
Turns out that the harness has been cut. I am looking for a uncut harness.
Cnorton1112
Engine Management and Tuning
Oct 15, 2015 05:52 PM
hmongboyLS
Jul 25, 2005 03:12 PM
Mr.Death
Sep 15, 2004 01:20 PM
fasterthenmost
Feb 25, 2003 07:19 PM
89JDMcrx
15
Feb 20, 2003 12:42 PM
