OK TECH GUYS!!! ANSWER THIS PLEASE...!!!! (ZC/SI TRANNY INFO.)
Old May 5, 2010 | 07:41 PM
devonb456's Avatar
Icon3 OK TECH GUYS!!! ANSWER THIS PLEASE...!!!! (ZC/SI TRANNY INFO.)
i AM GETTING MIXED INFO. ON ZC AND SI COMPATABILITY. OK, I HAVE A 89 DOHC ZC IN MY 89 CIVIC HATCH (NON SI). WILL ALL 89-91 SOHC AND DOHC SI TRANS. BOLT UP CORRECTLY? THANK YOU VERY MUCH!!!!
Old May 5, 2010 | 08:37 PM
91zchatch's Avatar
Default Re: OK TECH GUYS!!! ANSWER THIS PLEASE...!!!! (ZC/SI TRANNY INFO.)
ok is your zc a true zc and not a integra dohc motor if its a true zc you can use any D series trannys buy if its a integra you have you use a B series tranny so to answer your ? you can use that just make sure the splines are correct is all
Old May 5, 2010 | 08:44 PM
devonb456's Avatar
thx for reply man... its a true zc. so b4 i buy the sohc si tranny for my dohc zc, all i need to do is count the splines on both the input and output shafts for verification?
I just think its a lil weird a sohc trans. will bolt up correctly to a dohc motor. I didnt know that was ever accepted
devonb456's Avatar
how many splines does my zc have u know?
Old May 5, 2010 | 08:50 PM
91zchatch's Avatar
i think its 20 if not its 21
Old May 5, 2010 | 08:53 PM
devonb456's Avatar
ok good 2 know... thx a lot man!
Old May 5, 2010 | 09:37 PM
91zchatch's Avatar
no worries good luck
Old May 5, 2010 | 10:35 PM
DCRB's Avatar
ugh you guys search. 1988 d series trannies have 21 spline. 89-95 have 20 splines. 1988-1989 uses a smaller flywheel than 90-2000. as long as you have a true zc any non integra d series tranny will bolt up (from 88-2000). However, you will not be able to use the intermediate shaft from the DOHC ZC tranny on a single slam tranny. you'll have to get single slam d series axles that match your knuckles. assuming you have the DOHC ZC trans currently you will more than likely have the larger axle hubs any ways, so just get dx or si axles. but make sure you take your old axle in with you when buying new ones just to be safe.
BrayzieEF9
Mar 2, 2010 04:22 PM
xparalandrax
Nov 7, 2007 07:08 PM
JDM_EK_JOE
Jan 11, 2006 10:01 AM
ninjapanda
Nov 30, 2005 03:16 PM
Koyoloeor
Aug 9, 2005 04:19 AM
