the new project family hauler!
ok just got another honda finally after dumpin money into my 89 s13,havin a baby so i sold the 240 and got this [IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG].of course i had to keep my 180sx wheels lol. anyways let me know what yall think, theres a few things i wanna swap like the headlights and corners the turn signals in the bumper, a lip and get the stock tail lights. then the motor and 5spd swap.lets here the input!
[/IMG][IMG]
[/IMG][IMG]
[/IMG][IMG]
i had that problem with my civic....check map sensor, idle air, check egr, and make sure all plugs are connected in correct spots! 5spd swap is easier then u think man!
surging idle is common on these cars. REPLACE the fast idle valve, since its mostly that part that is bad. if you ever notice, those parts are pften gone in junk yards if the engine is still there. its gone for a reason and its because they go bad often. you should also replaca all the litthe coolant hoses from time to time as well. you can try that first but if it dont work replace the fast idle valve. also the iacv will also cause issues. try removing it and cleaning the port behind it and the screen on the back of the iacv. if that dont work replace the iacv. also make sure the coolant system is bleed correctly and that the coolant is not low. you should do this first but also if you remove any coolant lines for replacement
mr2kqql
22
Jun 15, 2003 06:42 PM
